User Tag List
Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 31
Thread: Transmission rebuild ( hard parts )
Transmission rebuild ( hard parts ) Transmission rebuild ( hard parts )
  1. #16
    Junior Member
    Join Date
    Sep 2015
    Posts
    46
    Post Thanks / Like
    My Feedback
    0
    (0% Positive Feedback)
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Re: Transmission rebuild ( hard parts )
    Quote Originally Posted by Pro Built Automatics View Post
    "the only thing I don't care for is the modified cast over run piston to fit the sleeved input drum"
    Why???
    I have had one crack on me ... smoked the trans
    Im not knocking the kit
    Sy #0535
    TBSS LME LS2
    non outlaw hardtop 911S
    911s 3.2 turbo
    75 3.2ss cab
    LS1 SS cam and spray
    LT1 355ci procharger
    LT1 WS6 383ci
  2. #17
    Super Member Slyclone's Avatar
    Join Date
    Jan 2011
    Location
    PA
    Age
    30
    Posts
    1,476
    Post Thanks / Like
    My Feedback
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Troyphoon View Post
    I finally spoke with him and got my kit ordered. Thanks
    What kit did you end up going with?
    1991 Syclone #678.
    1992 Typhoon #413 Sold
  3. #18
    Junior Member
    Join Date
    Jul 2011
    Posts
    28
    Post Thanks / Like
    My Feedback
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have only seen one crack since 1982, and that was in a core that I tore down. So what happened to you, is very rare. I have had many hundreds of these stock overrun pistons reworked since 1998 and have never had one fail (crack) that I know of.
  4. #19
    Member Troyphoon's Avatar
    Join Date
    Mar 2016
    Posts
    82
    Post Thanks / Like
    My Feedback
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Slyclone View Post
    I went with the pro street elite kit.
    1969 Camaro RS/SS 396 convertible 4 speed matching#s
    1987 Buick gn
    92 typhoon
    06 Yamaha r1 anniversary
    2012 cts-V coupe
  5. #20
    Join Date
    Jan 2011
    Location
    PA
    Age
    30
    Posts
    1,476
    Post Thanks / Like
    My Feedback
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Nice. Was curious about your build (engine). I dropped off my AWD transfer case and converter off to shop, like 2 weeks ago. I'm thinking it was a mistake... Only wanted a new seal put in. Been atleast 2 weeks no calls. Called yesterday after high noon and was expecting a call back and another day has gone by. I'm really curious to what they are up to. Wonder if something broke/went wrong and they have no way of explaining it? (only with me right!?)Transmission was a 1 week turn around. Maybe they will call me tomorrow?
    1991 Syclone #678.
  6. #21
    Join Date
    Mar 2016
    Posts
    82
    Post Thanks / Like
    My Feedback
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Oh boy I hate that feeling! If I where you I'd go buy the shop just to see what's going on. Unless it's a major crisis I don't feel there's a explanation for atleast a call back from anyone. Well good luck hope it works out for you. As far as my build motor is all stock with just bolt on parts,66mm turbo,60s injectors,tt chip,sportsmachines intercooler,Alky,CAI,2 walbros with Hotwire kit,3 inch Dp & exhaust no cat. Truck was running great 23# no knock and then trans started slipping.
    1987 Buick gn
    92 typhoon
    2012 cts-V coupe
  7. #22
    Join Date
    Feb 2011
    Location
    San Antonio TX
    Age
    34
    Posts
    85
    Post Thanks / Like
    My Feedback
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Did you finally get everything back? Really thinking of ordering this kit for mine.
    Alex
    '92 Typhoon #0718
    '09 Pontiac G8 GT
  8. #23
    Join Date
    Jan 2011
    Location
    PA
    Age
    30
    Posts
    1,476
    Post Thanks / Like
    My Feedback
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I did. Everything has been wating for me to install. I started digging the stuff out I had packed away.I went ahead and layed everything out . All the hardware and fastners, converter, support bars, gaskets so on.. I am hoping to install it myself very Soon.
    Bought a trans jack, so I am one step closer to getting the transmission in the actual truck.
    They cleaned the Transfer case and said the seals were in good shape.. no Need to change. Mentioned one was hard to find? A seal that is.they hit it with some paint and that was it. I asked them to provide me a transfer case gasket. I had a extra and cant find it.
    Attached Images Attached Images Transmission rebuild ( hard parts )-imag2411-jpg Transmission rebuild ( hard parts )-imag2563-jpg
    1991 Syclone #678.
  9. #24
    Join Date
    Jan 2011
    Location
    PA
    Age
    30
    Posts
    1,476
    Post Thanks / Like
    My Feedback
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Couple quick questions here in regards to locations/ parts :
    Photos the driver side lower trans area near linkage. I had about 12 normal pan bolts, and 2 odd balls. I'm not sure if you can see one of the two odd balls in but I feel like something is missing. A bracket? A piece of metal? It's really too bad this photo bucket thing took place. Makes looking back In time impossible. Good for photo reference. Not anymore.
    Secondly, energy suspension transmission mount. I have the one sandwich plate installed. Can someone verify if that part is needed or not. It's a piece of bent metal that goes (inside) the inner portion of mount. (Can be seen in photo) Thanks !
    Attached Images Attached Images Transmission rebuild ( hard parts )-20170913_160104-jpg Transmission rebuild ( hard parts )-20170913_160133-jpg Transmission rebuild ( hard parts )-20170913_160508-jpg
    1991 Syclone #678.
  10. #25
    Join Date
    Jan 2011
    Location
    PA
    Age
    30
    Posts
    1,476
    Post Thanks / Like
    My Feedback
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    ^^ there is a bracket missing. Not sure what it's called or where it is. Attached to two of the pan bolts, held the cable in a strait formation to link up to the bracketry on the trans; driver side. NO use in using the search bar here any more...seems like most the photos that I would refer to are gone now.
    Anyone have any input on the energy suspension polyurethane transmission mount.. with inner spacer plate?
    1991 Syclone #678.
  11. #26
    Join Date
    Jan 2011
    Location
    PA
    Age
    30
    Posts
    1,476
    Post Thanks / Like
    My Feedback
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    1991 Syclone #678.
  12. #27
    Combating adversyty. Quickstop [UK]'s Avatar
    Join Date
    Jan 2006
    Location
    London, UK
    Age
    38
    Posts
    6,690
    Post Thanks / Like
    My Feedback
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Your photos are all upside down.
    You are indeed missing the selector cable bracket. It goes next to the shift lever. It's long and narrow with a fixture to hold the cable.
    I don't think that suspension mount is a spacer. It's so you can bolt up a different support bushing. It won't do any harm there, just looks odd. Do you need the spacer? Probably not.
    : Photobucket
  13. #28
    Join Date
    Jan 2011
    Location
    PA
    Age
    30
    Posts
    1,476
    Post Thanks / Like
    My Feedback
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Mark, thanks is for the quick tip. Not sure why the photos are up side down ( just got another new phone ! Which is more of a easier way to support photo attachments )
    I wasn't sure about the spacer. Reason being I'm not 100% sure but can't recall if a remember any vehicle owners experience any clunking, or any type of offset angle on drivetrain, drive shaft or prop shaft. I am aware there is a small allowance but that bent piece of metal looks useless to me. Would never know if it loosens up ..had a issed already with the original. I did use better grade hardware with higher shear and yield strenght.I just want to know if others used that style mount of it's used or disgarded. When I first started working on my syclone 6 years ago I found that one of the bolts had sheared off inside the adapter mount as well as the other a short time later. I tried to extract them various ways and ended up obtaining a new one.
    Sometimes you over look stuff. I am relatively organized. Handed most the trans parts over to builder and thought that was with the parts. I crawled under my truck and in fact the part is still on the cable (false alarm) so I do have it. Thanks!!
    1991 Syclone #678.
  14. #29
    Join Date
    Jan 2006
    Location
    London, UK
    Age
    38
    Posts
    6,690
    Post Thanks / Like
    My Feedback
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hey man, don't apologise for a silly question. It's better to look foolish for a moment than be foolish forever.
    Always happy to help if I can. Fcuk those douchebags that belittle those who need help.
    Git r dun mate.
  15. #30
    Join Date
    Jan 2006
    Location
    London, UK
    Age
    38
    Posts
    6,690
    Post Thanks / Like
    My Feedback
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Git r dun mate.
Thread Information
Users Browsing this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
