User Tag List
Page 1 of 4 123 ... LastLast
Results 1 to 15 of 46
Thread: Syclone Missfiring
Syclone Missfiring Syclone Missfiring
  1. #1
    Member SycloneAndSHO's Avatar
    Join Date
    Feb 2016
    Location
    Sonora CA
    Posts
    89
    Post Thanks / Like
    My Feedback
    0
    (0% Positive Feedback)
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Syclone Missfiring
    Hey guys, hoping to get a little help on getting my truck running right. It's been running pretty bad lately and I don't know why. I've replaced the distributor cap, rotor, Ignition control Module, knock sensor, spark plugs & gapped them, and plug wires. It was running worse before, due to the spark arcing through the plug wire boot onto the manifold. The truck ran MUCH better when I replaced them, but slowly started to run worse again.
    The truck will also not go past 7 to 8 PSI of boost under full throttle, which is probably a good thing tbh because of how it's running right now. I'm getting 46 psi @ idle according to the fuel pressure gauge, so I seem to have fuel. Sometimes the truck will run OK ish, then other times it with run absolutely terrible. My guess is that it is ignition related due to what happened when I replaced the plug wires.
    I have an ALDL cable, but I don't have access to my laptop until probably tomorrow to do a log. Thanks for any advice, I really want to get her mechanically sound before I begin tearing it down for a Repaint and interior overhaul
  2. #2
    Join Date
    Feb 2016
    Location
    Sonora CA
    Posts
    89
    Post Thanks / Like
    My Feedback
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Re: Syclone Missfiring
    [IMG][/IMG]
    I also believe this may be ignition related due to the way my terminals look. Theres a bunch of build up, and it got there over a pretty short period of time.
  3. #3
    Senior Member IGottaSy's Avatar
    Join Date
    Jul 2006
    Location
    West Texas
    Posts
    729
    Post Thanks / Like
    My Feedback
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I would check to see if it's timed right, cap and rotor seated correctly and fuel pump pressure under load. Guessing weak fuel pump making engine run lean. Or clogged up injectors/fuel filter.
    Taking the streets by STORM!
  4. #4
    Don W.'s Avatar
    Join Date
    Dec 2002
    Location
    Santa Rosa, Ca
    Age
    74
    Posts
    6,851
    Post Thanks / Like
    My Feedback
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    46 psi FP is a bit high. If you have an adjustable FPR set the FP back to around 40-43 with the vac line -disconnected-. Have you checked/set timing? Should be 0 with brown wire under the dash disconnected. It will probably run like crap with that wire disconnected. It will, hopefully, smooth back out after timing is set and wire connected. Stock truck? Mods? Chip? That cap does look poor. Be sure you replace it with a copper terminal cap. Make sure wires are fully seated on the cap and plugs. When you replaced the ICM did you put the heat transfer compound under it? Get that log posted.
    As mentioned, FB should rise with boost, lb for lb. IE 10# boost should equal about 50# FP. And an injector cleaning might be worthwhile. The only kind that has ever worked for me is actually removing them and sending them out. What is the age if your injs?
  5. #5
    Join Date
    Feb 2016
    Location
    Sonora CA
    Posts
    89
    Post Thanks / Like
    My Feedback
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I believe it is adjustable since it appears to have and adjustment screw on top. I did check the timing, and it was set exactly at zero, but jumped to something different right at a certain rpm, can't remember what, but I think it's supposed to do that. Maybe the balancer outer ring is spun? I don't know how to tell. As far as mods, I'm not completely sure. I believe it has Vortec heads, according to the reciepts (And the valve covers say vortec), a Cam, not sure on the specs. And a few other things that probably reduce performance. Whoever did everything didn't do the greatest job on some things. I don't know if it has a chip, but I don't think so. The cap and rotor are all brass terminal. As far as heat transfer compound, no I didnt. I put a little die electric grease on it. When I asked for heat transfer compound at the auto parts store, they just looked at me funny and said they dint have it. And I couldn't find it either. As far as injectors, all I have done is run injector cleaner through the system. That's it. I will run a data log on it pretty shortly and get it posted, to see what you guys think.
  6. #6
    Join Date
    Feb 2016
    Location
    Sonora CA
    Posts
    89
    Post Thanks / Like
    My Feedback
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The truck is timed right according to the balancer, cap is seated (I've taken it on and off several times at this point), but maybe it is the injectors. I'm going to do a log and let you guys see wtf is going on. Thanks for the responses!
  7. #7
    Join Date
    Jul 2006
    Location
    West Texas
    Posts
    729
    Post Thanks / Like
    My Feedback
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    How old is your battey? Check voltages.
  8. #8
    Join Date
    Feb 2016
    Location
    Sonora CA
    Posts
    89
    Post Thanks / Like
    My Feedback
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Battery is fairly new and holds voltage. How the hell do I upload my Data logs from Tunerpro Rt????
  9. #9
    Senior Member Static's Avatar
    Join Date
    Feb 2010
    Location
    Apache Junction, AZ
    Posts
    703
    Post Thanks / Like
    My Feedback
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I had to replace my whole distributor. The magnets in the pickup were all cracked and rusty. Make sure to inspect yours
  10. #10
    Join Date
    Feb 2016
    Location
    Sonora CA
    Posts
    89
    Post Thanks / Like
    My Feedback
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I think I tried checking it a while ago, but I could not figure out how to get the thing off. I couldn't even really get my hands in there
  11. #11
    Join Date
    Jul 2006
    Location
    West Texas
    Posts
    729
    Post Thanks / Like
    My Feedback
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Check for spark plug wire arcing, again. Some of these plug wires can be damaged easily just by excessive bending or rough handling during packaging. What gap did you go with for the plugs? People have asked questions to help you in figuring out what is going on. Some of those have not been answered. The more you know...
    Do you have hard starts? Where's your IAC reading?
  12. #12
    I pity da fool liquidswords88's Avatar
    Join Date
    Dec 2015
    Location
    Michigan
    Age
    37
    Posts
    150
    Post Thanks / Like
    My Feedback
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Removing the dizzy requires a crows foot wrench. Access to the hold down bolt is pretty tight. It seems to me that dizzy removal is a good "gate keeper" for these trucks. If you can't get the dizzy out odds are the rest of these touchy difficult trucks is going to throw you for a loop.
    2nd place is the first loser!
  13. Likes Static liked this post
  14. #13
    Don W.'s Avatar
    Join Date
    Dec 2002
    Location
    Santa Rosa, Ca
    Age
    74
    Posts
    6,851
    Post Thanks / Like
    My Feedback
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    For the dist I use a 1/4 drive 9/16 wobble socket on a long extension. Works like a champ. Lot of stuff in the way down there. I've also used a short 9/16 box. No fun. Funny story here. When I first bought my truck I went to set the timing and the dist was just sitting there. The hold down was just siting there loose.
    You need to pull down the ECM (behind the glove box) and take the cover off, if the you see a blue cover it's a stock chip. With the mods you mention I suspect it does but you need to find out.
    Find a different auto parts store and find some heat sink compound and put it under the ign module. You can do this without removing the dist. Some of your symptoms jive with an overheated ign module.
    If the FPR has a screw on top then it's adjustable. Remove the vac line and reset FP to 40 with motor running.
    If you can screw both dist cap screws down then the cap is not on wrong.
    How did you change the knock sensor without removing the dist? Probably not your problem in the beginning but probably is now. If you screwed the knock sensor in tight then it's probably seeing non existent knock and may be part of your problems. It has to be torqued to a specific torque. 14 ft/lbs Do not use any sealant, only what it came with.
    Are you getting any codes?
  15. #14
    Super Member Slyclone's Avatar
    Join Date
    Jan 2011
    Location
    PA
    Age
    30
    Posts
    1,454
    Post Thanks / Like
    My Feedback
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    This is What I use for.removal of dist.
    Special distributor wrench.
    snap on makes them. Both of mine are vintage the 9/16 is # S9626. Personally wouldnt mess with it if you dont have correct tool. I played around with short stubby flank wrenches and Its just insane.
    Im wondering if you popped one of your Pistons? Do you have a stock bottom End? How was your driving style before the tune up?
    Compression test might be a better choice. Would solve a mega-ton of guessing.
    Attached Images Attached Images Syclone Missfiring-imag2472-jpg Syclone Missfiring-imag2471-jpg
    1991 Syclone #678.
    1992 Typhoon #413 Sold
  16. #15
    Join Date
    Feb 2016
    Location
    Sonora CA
    Posts
    89
    Post Thanks / Like
    My Feedback
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks for all of the responses guys, sorry for the late relpy, just got back from camping over the weekend. I will respond to all of your questions shortly, thanks!
Thread Information
Users Browsing this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Syclone Missfiring
Classifieds
