User Tag List
Results 1 to 14 of 14
Thread: radiator keeps blowing all the antifreeze into overflow.
radiator keeps blowing all the antifreeze into overflow. radiator keeps blowing all the antifreeze into overflow.
  1. #1
    Junior Member
    Join Date
    Apr 2002
    Location
    hopkinsville,ky,usa
    Posts
    36
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    i fixed the spark plug issue, now i keep loosing all my antifreeze into the overflow.i thought that when the coolant gets low in the radiator it suppose to pull it from the overflow.i didn't even go half a mile down the road and it has filled up the overflow(twice). do i need a new radiator cap?need some advice.TIA.
  2. #2
    Donating Member leroy's Avatar
    Join Date
    Sep 2000
    Location
    Lawrence, KS
    Posts
    1,213
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Check the cap and the hose going to the overflow. If the hose has a pinhole, it will suck air instead of coolant.
  3. #3
    Cascading Inspiration Ian Turgeon's Avatar
    Join Date
    Aug 2001
    Location
    Central Florida
    Age
    37
    Posts
    3,586
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    true, same thing if the cap is broken, it may only purge and not suck in coolant.. happens with the IC cap often.
    Ian.
    91 Syclone | 05 Elise | 13 FR-S
    howtune.com
    sytyarchives.com
  4. #4
    Join Date
    Apr 2002
    Location
    Pittsburgh PA
    Posts
    153
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It sounds to me like you blew a head gasket and are pressurizing the rad.
    Gary
    92 Ty #2414 Red/Gray
    KB Cold Air,
    3" cat back
  5. #5
    Jedi Council SyTyJedi's Avatar
    Join Date
    Nov 2000
    Location
    Valley Ranch, TX
    Age
    38
    Posts
    1,964
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Blown head gaskets are very uncommon in SyTy's. I suspect that there is some air in the sytem maybe? Try jacking up the front of the truck and then fill the radiator - this will help to burp some air out.
    Tyler
    '92 Typhoon
    '05 GTO
  6. #6
    Junior Member
    Join Date
    Apr 2002
    Location
    hopkinsville,ky,usa
    Posts
    36
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    bad newz must be a blown head gasket.put a new rad cap on and still pressurizing it out.saw some carbon deposits in the overflow tank. should i run it off into a river.
  7. #7
    jtz
    Guest
    When it is cooled down, remove the rad cap. Start it up and let it run for awhile. When your thermostat opens up you will see air bubbles in the rad if you have blown a head gasket. Just don't let it overheat while doing this, and be prepared to lose some coolant as it expands.
  8. #8
    Junior Member
    Join Date
    Apr 2002
    Location
    hopkinsville,ky,usa
    Posts
    36
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    i see bubbles lotsa bubbles is a blown head gasket the ONLY possible problem?kinda sucks since the motor has less than 400 miles on it.i used victor gaskets,torqued perfect.deck and heads were checked.what could have happened?
  9. #9
    Join Date
    Dec 2001
    Posts
    90
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    well, could be a cracked head. im sure you torqued the heads right?
  10. #10
    Evil Genius/SyTy Guru jwaller's Avatar
    Join Date
    Feb 2001
    Location
    Somewhere in the backwoods of SC
    Age
    41
    Posts
    5,430
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    that sucks man. it is definatly a blown HG. take it from a guy who changed one in the parking lot at NATS. you HG is shot. it could be a cracked head but you wont know till its torn down again.
    http://www.sportmachines.com/gallery...-his-creations
    10.73@ 127.05 AWD Typhoon
    "Life is tough, but it's tougher when you're stupid."
    John Wayne
    http://www.wallerperformance.com
    http://www.syty.net/forums/forum59/
  11. #11
    Join Date
    Apr 2002
    Location
    Pittsburgh PA
    Posts
    153
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I wouldn't tear it apart till you know what cylinder it is. Take a compression test. If there are no low cylinders, pressurize the cooling system, leave the spark plugs out and let it sit for a while. Then bump the starter a few times and see if any antifreeze blows out of a cylinder. At least if you know where the problem is it will be easier to spot when you pull the head. It might save you from pulling both heads too. Good luck and let us know what you find and if possible a reason for it doing what it did.
    Gary
    KB Cold Air,
    3" cat back
  12. #12
    Banned Jimmy's Avatar
    Join Date
    Jul 2001
    Location
    I-24 exit 4
    Posts
    12,169
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    WTF? That sucks ass Brian,sorry you're having such luck with that beauty.
  13. #13
    Junior Member
    Join Date
    Apr 2002
    Location
    hopkinsville,ky,usa
    Posts
    36
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    update/blown head gasket
    blown head gasket on #2 at the bottom into the water passage.
  14. #14
    Join Date
    Apr 2002
    Location
    Pittsburgh PA
    Posts
    153
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Bummer, any reason why? Head surface bad?
    Gary
    KB Cold Air,
    3" cat back
Thread Information
Users Browsing this Thread
Similar Threads
  1. Blown headgasket?? - coolant filling up overflow
    By BoostedSUV in forum Engine & Exhaust Tech
    Last Post: 09-27-2010, 08:14 PM
  2. Antifreeze leak
    By wantingasy in forum Engine & Exhaust Tech
    Last Post: 02-19-2006, 01:57 AM
  3. Antifreeze Ghost
    By home in forum Engine & Exhaust Tech
    Last Post: 07-17-2005, 08:13 AM
  4. Non AC Blower Motor keeps blowing fuse!
    By HighPerformanceTrucks in forum Chassis Electrical & Accessories
    Last Post: 04-23-2004, 06:27 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
