"Phoon" 1993 TY 0935
  • "Phoon" 1993 TY 0935
    On Sept 28 2015 I picked up 93 TY 0935 (Phoon as my black truck is already called Ty) in Abilene TX, at the time I was told the motor had been rebuilt and just needed finishing up the installation. Yeah so not the case also some cladding was damaged the drivers side rear to kick panels needless to say it needed some work and I figured it would make a good project.
    Started off by tearing the "rebuilt" motor down and sent the block to the machine shop of course they measure it and recommended bore it .030 over decking the surface and line boring the the mains and turning the crank 10/10 plus forge pistons. This project got off track from the beginning I only wish I would've put eagle rods in to it at this point but at the time was tying to stick to something of a budget. I built the motor with probe forged pistons stock rods and crank 412 comp cam found some L35 heads with screw in rockers used comp cams self aligning roller tip rockers hardened push rods Alex's springs and retainers.
    My goal was to keep it close to stock as I plan to drive it on weekends to shows and car runs and the such. I also added ARP head studs and misc Arp hardware fluidampr harmonic balancer powdercoating most parts ceramic coating the exhaust manifolds and crossover pipe. Rebuilt the whole front suspension upper and lower control arm bushings upper and lower ball joint new cv axels Eric Tinns posi front axel. might as well ad a 3k stall converter deeper trans pan and cooler while the motor is out right? Solid motor mounts Jeep steering shaft all the typical upgrades.
    Cleaned and repainted the frame etc etc.... I've been slowly working on this thing for almost 2 years and am about to drop the motor in to place and reassemble the front end then change the fuel pump get everything wired/ hooked up order a turbo tweak chip and hopefully get it running by the end of summer if I dont take a 2nd part time job first LOL I will keep adding more pics and listing more parts I've used as I think of them.
    Re: "Phoon" 1993 TY 0935
    Good stuff!
    Taking the streets by STORM!
      Got the motor back in Phoon transmission bolted up solid motor mount tightened upfront diff installed got the grounds on the rear of the heads bolted down I actually made a few jumper wires to tie all the grounds together hoping to avoid any issues with those!
      Click image for larger version
ID:	1656475Click image for larger version
      • #4
        lookin good. Nice and clean
        92 Typhoon #999 SEE 10.27 RUN http://youtu.be/Pw6YKBEBfu4
        91 Syclone #788 SEE 10.22 RUN https://youtu.be/IhXj12U06oQ
        91 Syclone #2891
        WWW.AUTOADDICTIONSINC.COM
        WWW.MYAUTOADDICTIONS.COM
        • #5
          Got some work done on the front suspension and brakes as well as all the vacuum lines ran got the ac compressor mounted and the alternator radiator and fan shroud in place as well as the transmission cooler mounter and plumbed ordered a Turbo tweak chip and am hoping to get her running soon ��
          • #6
            Making some progress I removed the rear leveling system along with the wiring as it was not being used any more and ran my Hot wire kit for the fuel pump in place of that wiring. I cleaned the entire frame and repainted everything. I also removed the rear axel and springs and replaced them with Beltec lowering springs painted the shocks and rear cover to match all the other red. I ran new brake lines to the Camaro rear disc set up. I still need to figure out the parking brakes. I also installed the sportmachine lower dual pass water to air cooler and worked on various little things under the hood.
            • #7
ID:	1859433Click image for larger version
ID:	1859434Click image for larger version
ID:	1859435Click image for larger version
              • #8
                Been attempting to get this thing to start up the past couple weekends had no fuel pressure at first tracked that to a miseries fuel pump which was an easy fix that entailed a lot of work then we pushed it out of the garage to attempt to fire it and it had no brakes what so ever but since it was out there already we decided to fire it up and get the timeing set and at least make sure everything else would work and it actually fired up easily we set timer by and ran it in a bit allowing it to reach temp found a couple small water leaks so we will address a few more issues before we can put it on the road and do more tuning
                • #9
                  such a sweet bay you got there perfect color combo!
                  • #10
                    Thanks it took a while to get it done!
                    • #11
                      The finished mostly project
                      • #12
                        Nice, I like this one!
                        • #13
                          Been looking in to the water leaks I found when I started this thing up and first thought it was the turbo coolant return where it feeds back in to the block cuz it was dripping off of there. I pulled the line off the fitting end was damaged thought that had to be it and replaced it. It turns out that was not it, so my next thought was the freeze plug behind the motor mount must be leaking knowing that would require pulling the motor again. I wanted to be sure it wasn't anything else (also lost the desire to work on it for a while and got busy with life) so I pulled the exhaust manifold off to get a look at the head and gasket (I really was not looking forward to pulling the motor back out again so soon) and boy am I glad I did because I found 2 head studs leaking right above the freeze plug. A bit of searching and I found out that this is a fairly common issue. To be thorough I am going to check all the head bolts meaning removing both exhaust manifolds and valve covers and remove any leaking ones one at a time and resealing them. The only good part is at least every thing I have to pull apart is nice and clean and new I guess. I thought I had a second leak at the rear center of the motor from the trans inspection cover and thought it might be the rear of the intake so I tore all that apart to be positive it was not an issue finally tracked that back to the same 2 exhaust bolts and the coolant was traveling along the lip of the oil pan and back in to the inspection cover near the starter. I ended up finding a total of 3 leaking ARP head studs 2 external on the pass side head and 1 internal on the drivers side head. I made the decision to remove all the head studs 1 by 1 and reseal them all hopefully preventing any farther issues I hope! I refilled the cooling system and pressure tested it and do not see any leaks now I just have to re-assemble everything.
                          • #14
                            At this time due to multiple site malfunctions I have decided to move this build over to the ISTR Forums. I hope anyone interested will be able to follow along over there.
                            On Sept 28 2015 I picked up 93 TY 0935 in Abilene TX, at the time I was told the motor had been rebuilt and just needed finishing up the installation. Some of
