Vintage Air Install
  • Vintage Air Install
    I thought I would post a few pictures of the Vintage Air system that I installed in the Syclone. Everything works great and it cools and heats well. It is the "Mini" model. I already had the "Frontrunner" accessory drive installed on the truck, but I don't see why this wouldn't work with a stock compressor.
    Click image for larger version
    sigpic1991 Syclone 2373, With a few mods
    Re: Vintage Air Install
    The work in progress:
      Randy,
      The install looks real good and first time I seen this with the vintage system.
      1993 GMC Typhoon #1215 (10.71@124MPH Stock Bottom End)
      Typhoon 2.0 Build: 10.49 @129 Forged Internals, Block Fill, 4 bolt, High Compression, Brodix -8 Ported Heads, Custom Cam, Headers, E85, Holley Dominator, Built 4L80e
      • #4
        can you post up a clearer picture of the controller?
        92 TY # 398 - Retired DD - 162K and running good: 20G, JSM A-Arms, QA1 Coilovers, Beltech rear springs & SB, ZQ8, F-Body disks, Gilbert, built trans, 9/11 convertor, C4 ZR1 wheels, Hoods ABS delete, DutchTy IC & Johnson pump , RPM cat delete & Borla cat back exhaust, Code$59 tuned by Krupa running on E85.
        97 Tahoe - Big Blue
        • #5
          • #6
            What system is that? vintage air magnum?
            syclone #0954
            bro has sy #0480,1900
            • #7
              See first post. Mini.
              • #8
                Looks great
                keith - syty.net Admin
                • #9
                  VintageAir says that the Magnum is 1.5" taller and 7" wider than the Mini. Based on your experience, do you think the Magnum would fit a SyTy?
                  V~
                  Sy 1264 SoGT 264 93 Ty 0757 96 Bravada Where's Ty 2264?
                  • #10
                    No, I don't think the Magnum would fit. It was a very tight squeeze to get the Mini installed. The width would be the main problem.
                    • #11
