Front/rear alumnium bumper support
  • Front/rear alumnium bumper support
    I inspected them and they are easy to make.
    front bumper support is so heavy.
    also rear.
    so Iím gonna convert them to aluminum bumper support, very light one.
    Keep eye on it.
    John
    91 Syclone #644
    87 Jimmy S15 2wd V8 TPI
    86 Z28 355 high modify
    That would be great . Let us know how it goes amd how
    much weight you cut . I would pay for this if weight is significant .
      Doing some frame. Soon do the brackets for the turn signals and fog light plus some brackets/supports for bolt on the frames. It going to be so lightly!
      John
      91 Syclone #644
      • #4
        I weighed it without a cover, 23.3 lbs. everything include fog light, turn signals and braces. So around 24-25 lbs with cover.
        ill update on weigh of the aluminum one after done 100%.
        John
        91 Syclone #644
        • #5
          I weighed bare steel bumper support and my homemade aluminum bumper support.
          15+ pounds saving without a side braces itís pointless to use them.
          steel = 20 lbs
          aluminum = 4 lbs
          for just front bumper support.
          yes it holding solid good enough.
          rear is NEXT!
          John
          91 Syclone #644
          • #6
            Im interested in a front bumper support as well.
            10.4@127mph-stock ECM
            542 rwhp/ 608 Torque. PTE 67-V6.
            E85-TT-408"-AWD/4L80e under construction...
            • #7
              Almost done and itís sooo light!!
              Gonna install those led foglight.
              Thanks Sean Krupa for lead me to LED foglight!
              John
              91 Syclone #644
              • #8
                Driver side is next to install turn signal and foglight.
                may need to adjust on foglight little bit.
                John
                91 Syclone #644
                • #9
                  Done and itís very light than you can imagine!
                  John
                  91 Syclone #644
                  • #10
                    It is holding solid!
                    John
                    91 Syclone #644
