Sonoma GT 0334 - Build Pics
  • Sonoma GT 0334 - Build Pics
    Current Project Sponsors
    www.compfab.com
    www.autometer.com
    www.airbagparts.com
    www.stainlessworks.net
    www.billetspecialties.com
    www.precisionbrakescompany.com
    www.sportmachines.com
    www.mirradographics.com
    Good Morning All,
    Okay i plan to post picks and build info and keep updating this thread till the truck is complete.
    http://www.sportmachines.com/gallery/Sonoma-Gt-0334
    Stage One -Dissasembly
    http://www.sportmachines.com/gallery/stage-one
    Removal of Bed
    Removal of Front Clip
    Removal of Cab
    Remove and Discards part not wanted on Frame
    Sandblast Frame
    Repair Damage Body Mounts
    Paint Frame
    Stage Two - Wheels & Tires
    http://www.sportmachines.com/gallery/wheels-tires
    18 x 8 SLG20 Soft Lip Wheel225/45 18 BFG KDW-220 x 10 SLG20 Soft Lip Wheel295/45 20 BFG KDW-2
    Stage Three - Rear Suspension
    http://www.sportmachines.com/gallery/sogt0334rs
    Special Thanks - Comp Fab, Dustin Performance, Wilwood, Currie Enterprise
    Moroso Wheels Studs
    Wilwood Disk Brakes
    Aluminum 9" Ford - Aluminum Third Member
    Custom 4-Bar w/Anti-Roll Bar
    Afco Coil Over Shocks - ???lbs Spring
    Poly Suspension Stops
    Stage Four - Chassis
    http://www.sportmachines.com/gallery/chassis
    Special Thanks - Comp Fab, RK Kustoms, Bad Ass Bowtie, Village Auto
    Frame Boxing & Chassis Modifications
    Tubular Frame Cross Bracing
    Tubular Drive Shaft Loop
    Tubular Trans Mount
    Poly Trans Mount
    Rear Tie Down
    Frame Pad
    Frame Pad Modifications
    Motor Mounts
    Front Tie Down
    Stage Five - Front Suspension
    http://www.sportmachines.com/gallery/sogt0334fs
    Special Thanks - Comp Fab, Dustin Perfromance, Village Auto, Pro-Tec Powder Coating, Hi Speed Welding, Air Ride, Hotchkiss, Summit Racing, John Waller, Rockford Racecraft
    Shock Wave - Air Ride Upper & Lower Control ArmBell Tech SpindleWheels StudsLug Nuts MetricHalf Shaft RetainersHalf Shaft Bolts Half Shaft NutsBOLT 2 REQ - Upper Control ArmTORQUE LOCKNUT A/R BOLT 2 REQ - Lower Control ArmTORQUE LOCKNUT A/R Moog Idler ArmMoog Center LinkMoog Tie Rod EndsBear TrackersBellTech Sway BarAGR Steering Box20" SBE Plated Polished Shaft3/4" -36 x 1" -48 U-Joint Polished3/4" -36 x 3/4" -36 U-Joint Polished
    Stage Six - Fuel Delivery System
    http://www.sportmachines.com/gallery/fueldeliv
    Special Thanks - Hi Speed Welding, Race Proven Motors
    Fuel Cell with Baffles
    Fuel Sending Unit
    Roll Over Shut off Valve
    Fuel Cell Tank Holder
    "Y" Block w/Hobbs Switch
    Weldon 150gph efi pump (-12in -10out)
    SX Billet EFI Fuel Filter, slimline -10 inlets
    Tubular Cross Member Mount
    Weldon Dial A Flow "1400 Pump Controller"
    Fuel Line & Ends
    Fuel Line Cooler
    AN8 Fuel Return Line & Ends
    Weldon Fuel Pressure Regulator
    Stage Seven - Paint & Body - Cab
    Special Thanks - Comp Fab, Rockford Racecraft, Peter Humblias, Valley Welding
    http://www.sportmachines.com/gallery/p-bcab
    Roll Cage w/Side Brace
    Cab - Media Blasted
    Cab - Etched and Expoy Primer
    Rocker Panel Repaired - Body Work
    Body Mounts Repaired
    Firewall Smoothed
    HEX BOLT-CAB/RADIATOR MOUNT
    FLAT WASHER A/R
    RETAINER
    SHIM-CAB MOUNT A/R
    Poly Body Bushings
    SCREW A/R
    C.R. Laurence - Back Glass
    COWL SCREEN 1 REQ
    Windshield Shaded
    Windshield Trim-Black
    Exterior Rubber Kit
    Drivers Side Door
    Passenger Side Door
    DOOR WINDOW SEAL-OUTER-LH
    DOOR WINDOW SEAL-OUTER-RH
    DOOR WINDOW SEAL-INNER 2 REQ
    Cal Vue Power Signal Mirrors
    Door Lock Gaskets
    Stage Eight - Brakes
    http://www.sportmachines.com/gallery/sogt0334eng-trans
    Wilwood Pedal Dual MasterWilwood 7/8" MasterWilwood 1" MasterWilwood Remote AdjustWilwood 14.1" Front BrakesWilwood 14.1" Rear Brakes
    Alot more to Come.
    marty-mj (( sportmachines@hotmail.com ))
    Syclone Typhoon or Sonoma GT Parts and cladding available
    Syborg Twin Turbo Web Design - Fuel Injected Media
    Competition Fabrication, Kenny Davis Hot Rods, Recovery Room Interiors, Race Proven Motors, Ride Tech, Autometer
    Nice! Can't remember a GT getting this much love...
    JEREMYŽ
    Nats 2005, 2006, 1/8 of 2007
      that is looking really, really good!!!!!!!!!!!!!! ::ok::
      '92 Typhoon BLK/BLK #1244 SOLD
      '91 Syclone Stock #1801 SOLD
      '91 Syclone #1763 SOLD
      '93 Typhoon WHT/WHT #2076
      '93 Typhoon WHT/GRY #1780
      '91 Syclone #0464
      What can you say?.............................addicted!
      • #4
        Thanks guy's
        • #5
          Wow man, very nice. It looks like you have more into just that 4 link and front suspention that I have into my whole truck :-?
          That will be a nice rig when it is done!
          Brian
          I don't own a sy/ty, I used to!
          • #6
            i don't even want to think about how much money i have in this truck. I lost count when it went over 40k
            • #7
              You must not be married
              My wife is mad at me for just spending a few grand on a new motor
              Brian
              • #8
                1st wife - she told me it was her or my syclone
                - i told her i was going to miss her
                - she said i was going to miss some of my money
                - she had a great atorney (not good - great)
                - she was correct she got all of the furniture and my money
                - i got the syclone, 1/2 of bedroom set and an empty house
                2nd wife - new what she was getting into
                - she actaully bought me the gt
                - as long as i don't spend house moeny on the truck she doesn't care
                - thus the Part-time / full time second job (buying and selling parts)
                - did i mention the lack of sleep that goes with the second job & 2 kids
                so if you ever meet her, just keep it a secet how much money is in the truck
                • #9
                  Marty,
                  What's sad - as great as the pics look - it is 25 times nicer in person. This thing is a work of art.
                  I can't wait to see it run in 3 years
                  RIP Myclone
                  Smeagol's Therapist - I'm failing miserably.
                  • #10
                    Originally posted by GM TURBO
                    Marty,
                    thanks Dave - but you know i still love your truck
                    • #11
                      I am sure a lot of SyTy owners are going to be jealous/embarrassed when this thing waxes our arses. I now have a thread subcription to enjoy. Looks great.
                      Zach
                      Divergent lightning wrote:
                      "My roommate was going over honda-tech.com and a post asked: when you see a truck do you think you can beat it?
                      all responded yes save for this post:
                      Yes, unless it's.... one of those GM turbocharged monstrosities that aren't really trucks at all, they just look like one.
                      • #12
                        Zach
                        Since the 02 nats no one (Dave - GM Turbo) has let me forget how bad i am at the lights. So when the time come's i'll be looking for a driver.
                        Any takers
                        • #13
                          Zach
                          Any takers
                          you pay my ticket??
                          '91 Syclone #0464
                          • #14
                            from the Neatherlands - Huh
                            that might cost alot - but what the heck
                            • #15
                              Marty - you let me drive - I'll pay the track fees
                              Plus I live closer.
                              RIP Myclone
