Erratic tachometer
  • Erratic tachometer
    Hi,
    New here on this forum with a couple of questions. I just bought a 92 Typhoon with an erratic tachometer, it shows 1500 on idle and 7000 when it shift up.
    Is there anything I can do to fix that or do I just replace it? Thinking of putting in an aftermarket tach but don't know what wire I should use for input pulse.
    Getting an user cluster is not an option as there are nothing available in Sweden, only a handful cars total. Advise highly appreciated.
    Thanks,
    Matt
    Mine GT is doing the same thing. I was thinking of trying this:
    http://www.syty.net/forums/forum/syt...on-information
    sigpic1991 Syclone 2373, With a few mods
      That's a little out of my league, anyone knows what wire to use for an aftermarket tach?
      • #4
        It's the white wire in the coil plug. You can also grab the signal at the C101 connector - which is about 1ft (that's like 30 centimeters for you filthy Europeans) up under the passenger side dash. It's the white wire there also.
        Justin "RealFastV6"
        1991 GMC Syclone
        1993 GMC Typhoon
        • #5
          Thanks,
          I'll check and see what I'll find
