No start after new engine install
  • No start after new engine install
    Hey guys,
    So I just put a new engine in my Ty ( rebuild) and now it won't start. Before removing the old one it started right up. Truck sat for about 7 months and I don't see why that would be an issue? When I turn the key I don't hear the long beep anymore.
    Everything is new on the engine.
    New plugs, wires, coil, dist, sensors, injectors, etc.
    I have fuel pressure.
    All fuses are good.
    Is there a way to test the ECM?
    Is the ECM from a Ty the same as a Sy? (I ask cause I have a Sy one that I can use)
    Any help or tips are much appreciated.
    Thx
    91' Syclone #1129
    92' Typhoon #1061 (DD)
    11' Toyota Camry SE
    Does it turn over?
    Do your headlights come on?
    If not, are you sure you hooked up all of the wiring to the started and the alternator?
    Mike
    92 TY#0073
    93 TY#0965-SOLD!
    2007 Trailblazer SS - Wife's new ride
    It's tough being narcissistic, especially when you realize that nobody wants to be like you.
      Yes, we need to know if it turns over. If it is are you getting a spark at the sparkplug? I have had to move the distributor to adjust the timing a little to get the engine to start initially.
      One time I installed the plug wires incorrectly. Reverse from the direction the distributor rotates. Not good. Should be1-6-5-4-3-2 distributor rotates clockwise. Please let us know more details.
      Phil
      91 Syclone 2097
      92 Typhoon 0042 Black/Black
      93 Typhoon 1955 Royal Blue
      • #4
        Today I got home and figured I just check the alternator connection and I found the red wire was coming off the connector. fixed it and I thought it might be it, but nothing. The engine does turn over, and very well. My headlights do turn on. The one thing like I mentioned in my first post is that when I turn the key I don't hear the long beep sound nor do I see any lights come on in the dash. Only the Check Engine light comes on then turns off as usual. Before removing the engine it started just fine and all the lights came on before start up. I feel like I'm not getting spark to the plugs but kinda lost at this point. Wires are in the rotation that they need to be in. 165432. I've tried moving the dist. and nothing. I even removed it just to make sure I wasn't 180* out. I'm at TDC on compression stroke and nothing. This SUCKS!!
        91' Syclone #1129
        11' Toyota Camry SE
        • #5
          Jay,
          Is the ground connection point on the back of the Drivers head clean? You mentioned that the motor was rebuilt and if you painted the heads it might not be getting good ground (had this happen a few years back on a Grand National after a motor rebuild). Also unplug and reinstall the distributer wires a few times as it might not be getting good contact.
          Bob
          • #6
            Thx for the responses fellas.
            Yup, just to make sure I sanded the area and installed the ground. All the grounds in the engine bay, I made sure they had good contact. Distributor wires have been disconnected and reconnected a few times. I did notice today that the "check gauges" light came on...but only sometimes when ever I turned the key to start. A few questions...
            If I have fuel pressure to the fuel rail how can I tell if the injectors are pushing fuel through them?
            I have new injectors...could they be bad?
            Other than a screw driver to ground, is there another way to test spark from the distributor
            Could it be possible that I have a bad ICM even though its brand new w/distributor?
            Mannnn this thing is taking me for a ride!
            91' Syclone #1129
            11' Toyota Camry SE
            • #7
              Are the injectors impedance matching the ECM and chip programming?
              I believe you can fry it or at least fry the drivers if they don't match.
              brown wire reconnected?
              I know this is trivial but, battery terminals are clean and tight as are starter and alternator?
              No wiring caught between transmission and engine?
              Taking the streets by STORM!
              • #8
                Yup, OEM 42lb injectors. When you say brown wire, are you talking about the tan ( bypass) wire? No wires caught, and battery terminals clean, as well as starter and alternator.
                91' Syclone #1129
                11' Toyota Camry SE
                • #9
                  Today I messed around with it again and discovered a black/white and a tan wire behind the engine block that are suppose to be grounded. They were disconnected and I said to my self...it must be it annnnddd Nothing. Glad I found that though. I decided to check my DM and its throwing a code 43. Oh man here we go. Knock sensor or ESC? Don't quite understand why if everything is brand new. I'm hoping and praying this is the issue that gets solved. Any help would be greatly appreciated.
                  91' Syclone #1129
                  11' Toyota Camry SE
                  • #10
                    I think code 43 is set when the tan timing wire is disconnected.
                    Dave
                    Sy #2661
                    • #11
                      The stock injectors aren't 42#.
                      I had some issues when getting my truck started after putting it together. I just had the timing wrong.
                      Dave
                      Sy #2661
                      • #12
                        Thx..Yup, 32lb. Checked the tan wire and its connected. I will be be checking the timing chain to make sure I didn't miss a tooth, I'm sure I didn't but at this point what the heck...wont hurt to check.
                        91' Syclone #1129
                        11' Toyota Camry SE
                        • #13
                          Did you ever check to see if you were getting a spark to the plugs? There is a tester for this but I usually put an old spark plug in number 1 wire and lean the metal of the plug against a grounded object on the engine. Make sure you don't have any fuel leaks.
                          Is the injector harness plugged in? The issue is most likely something simple. Make sure you are getting fuel and spark. Then make sure the spark is happening at the correct time on the correct cylinder.
                          Phil
                          91 Syclone 2097
                          • #14
                            I tried it with a screw driver but I'll also try what you mentioned. Probably more accurate. Injector harness is plugged. Yes those 2 things I need to confirm for sure in order to move forward. I'll give it another go tomorrow ( cause I'm kind of over it right now) and do and update. Thx again for the replies.
                            91' Syclone #1129
                            11' Toyota Camry SE
                            • #15
                              Try checking to make sure the ECM fuses aren't blown. I can't remember if our trucks have an INJ fuse, if we have one of those check that fuse as well.
                              Dave
                              Sy #2661
