OddFire v6 Blow thru e85
  • #46
    Re: OddFire BS3 e85
    Originally posted by djsy934 View Post
    The hacking of the stock cross member for the deeper pan only?? The mount points should have been in the correct location. This is good information feedback for me to know.
    yep, just so that pan would clear. Everything else fits good.
    Thanks
    Ty369 (original owner) Best 11.46@117.39 PTE51 http://www.youtube.com/watch?v=s-TOBZECLeU
    Denny NY
    Bowtie block, steel crank, vortec heads, 4l80e, Precision billet 6768, Cambell custom cam, HTP 50 lber
    Sy303 (Frankensy) - 23 deg oddfire BS3 efi E85 - th400 - walbro 450LPH, 160lb, unknown CR
    • #47
      Re: OddFire v6 Blow thru e85
      Originally posted by 0966Sy View Post
      Hey Denny, wow you have a lot of dedication. You got the BS3 update done yet or are you still working off the old version? I haven't updated mine yet, I'm so used to the old version I'm nervous to update.
      You still plan on keeping this IC free?
      Get it done you won't look back. It's easier to use and the auto tune feature is magnificent.
      92 Typhoon #999 SEE 10.27 RUN http://youtu.be/Pw6YKBEBfu4
      91 Syclone #788 SEE 10.22 RUN https://youtu.be/IhXj12U06oQ
      91 Syclone #2891
      WWW.AUTOADDICTIONSINC.COM
      WWW.MYAUTOADDICTIONS.COM
      • #48
        Re: OddFire v6 EFI e85
        I live in a city, no place to test drive. Closest track is 2hrs away.
        Running 9lb boost right now and it comes alive after 5k rpm.
        I have a 5.3 ls that I might start building this summer.
        Crap done so far in case I decide to sell the truck or part it out or sell the engine.
        New fuel tank
        New fuel sender
        New Walbro 450 e85 pump
        Teflon fuel lines 8an feel 6an return
        billet fuel rail / regulator
        1” drop block
        Ls1 front brake conversion (Renz adapter, powerstop caliper/rotor)
        Dyi Abs delete
        Th400 awd (billet tcase adapater, rspline outputshaft, racerchoice converer)
        DD front propshaft
        RPM Crank trigger kit
        Getto FM intercooler / bov
        RPM custom headers and downpipe
        ITS 72mm BB turbo / ITS wastegate
        BOWTIE ODDFIRE
        Steel crank corrillo rods/ Je piston
        Flexplate, convert dry to set sump (machine rear main cap)
        23 deg bowtie heads
        Billet turbo roller cam
        Timing chain
        Renz upper front facing intake
        BS3 efi
        Felalite dual fan
        Msd oddfire box
        Denny’s custom distributor for cam sync
        RPM Ac delete
        RPM motor mount
        Denny NY
        • #49
          Re: OddFire v6 Bs3
          Traction bar
          Trip to Homedepot to get shrubs.
          Denny NY
          • #50
            If the engine is a true odd fire, you can't change to an even fire without changing the crank and cam, before you mess with the ignition.
            • #51
              Denny NY
              • #52
                Originally posted by fivetodrive View Post
                Awesome Denny. I didnt know they had a 27spline output shaft for the th400
                I think they're technically called a TH375. Basically a light duty version of the TH400 with no relation to the TH375B.
                • #53
                  I bought the th400 from someone on Craigslist, I tried telling the seller that is not a standard output shaft. He dosent believe me because he thinks I want to lowball him.
                  Transmissiononline I believe have 27 spline output shaft for th400.
                  Denny NY
                  • #54
                    Denny NY
                    • #55
                      its been a long way -
                      Denny NY
                      • #56
                        Very nice! Good job.
                        Phil
                        91 Syclone 2097
                        92 Typhoon 0042 Black/Black
                        93 Typhoon 1955 Royal Blue
