Turbo- Banjo vs AN
  • Turbo- Banjo vs AN
    I was wondering if anyone here has swapped their turbo water feed/return lines with AN fittings? Most curious about the banjo. Looking to do AN fittings but not sure if it'll change anything? I know banjo's are made for pressure so that's why I ask. Any help/input is greatly appreciated.
    91' Syclone #1129
    92' Typhoon #1061 (DD)
    11' Toyota Camry SE
    I have swapped the water feed and return lines for AN. It may be a bit tricky if you have the stock a/c compressor. Mine is wide open. You can see the feed line in this pic if you zoom in. Click image for larger version
    sigpic1991 Syclone 2373, With a few mods
      Yup, exactly what I was looking for. Thx for the pic. Loving those valve covers ( hard to find)
      91' Syclone #1129
      11' Toyota Camry SE
      • #4
        Hey Randy.. Are you running a block off plate for your fan motor? I see a heater hoses so Iím a bit confused. Looks good
        Syclone #0585
