Eliminating vacuum lines
  • Eliminating vacuum lines
    I want to remove most all my vacuums lines. Just finished completely rebuilding my motor CP 40 over pistons, eagle rods, nitrate crank, vortex heads, comp cam, 20g billet turbo, 8mm wires streetfighter, ngk UR6 plugs, msd street fire coil, RC injectors, 3bar map sensor, all sensors new and 160 thermostat. It has a bad mis, shakes alot while in idel. Does not go into boost. I'm stumped. I've connected all the vacuums correctly and still rough idle, and no boost. Anyone in the miami area can tune the truck. Also can I eliminate all the vacuums. Thanks
