Fuel pump sending unit
  • Fuel pump sending unit
    i came across two different fuel sending units from rock auto that state will fit my ty but are extremely different in cost. One is 53 dollars and the other is 251 dollars. Who can tell me if the 53 dollar one is the correct one. Maybe they just have the wrong info on there site.
    Or if anyone recommends some place please let me know.
    Thanks
    1993 Typhoon #1889 "AWDBOOST"
    Re: Fuel pump sending unit
    Did some more searching and it looks like 1AAuto has this stated...Can this be true!!!!!!!!
    List Price:$424.03
    SAVE
    86%
    Our Price: $60.95
    (You Save $363.08)
    Free Ground Shipping
      I had heard that the good Delphi unit can be that expensive and the garbage Dorman can be had for less than $100. I will probably crack and get the good one when it comes time to drop the tank--Some aftermarket stuff I do not trust at all!
      Joliet IL--Home of Rt.66 Dragway
      1993 Typhoon Red/Gray #0087**SOLD**
      2001 Lightning**SOLD**12.9 @ 105 on an OZONE action day!
      1995 S-10 SS *SMASHED**
      "Look at all the happy creatures dancing on the lawn!"
      sigpic
      • #4
        What is the manufacture brand name that the TY's have from stock? What are the ones people are using for replacement?
        • #5
          I bought $53 one... Worked perfectly
          '92 Typhoon #0182: +.030, SRP pistons, Eagles, Comp 422, 1.6 rollers, Waller vortecs/700r4/3000 stall 9/11, PTE6265, 3" DP w/dump, ATR exhaust, AFPR, 255lph Walbro, 63#ers, 3 bar map, 52mm BBK, RPM A/A IC, MSD 6A, billet dist/coil/wires, TR7ix. Tuned by Nolan, C5 brakes Autometer boost/elec FP, PLX WBO2, Greddy Boost Control. Belltech leafs/sway bar, bilsteins, ZQ8, Eclipse 7" in-dash DVD, 2 12"subs/ 2 amps, rolling on 18" Z06's
          • #6
            me 2. cheap one works well. and you prolly never touch it again anyway
            '92 Typhoon BLK/BLK #1244 SOLD
            '91 Syclone Stock #1801 SOLD
            '91 Syclone #1763 SOLD
            '93 Typhoon WHT/WHT #2076
            '93 Typhoon WHT/GRY #1780
            '91 Syclone #0464
            What can you say?.............................addicted!
            • #7
              I know its just a picture but why does the Dorman and the ACDelco on rock auto look so different. That gets me worried. I havent taken the old fuel gauge sender out to compare. What does our original part look like????????????????Dorman or ACdelco.
              • #8
                Originally posted by Ty0331
                Read this thread CAREFULLY. You can get easily confused with the different senders. all of the info is in there, along with links. Just take some time to sort through it.
                Thanks ty0331 but the only thing i got from that thread was using a 13 gallon or a 20 gallon sending unit. I want to know do i need to spend 250 dollars on a unit that i can get for 60 dollars.
                • #9
                  That may be why the pics on rockauto are "so different". I, personally, wouldn't waste my time with the Dorman piece.
                  • #10
                    Okay guys well i decided to get my new walbro fuel pump, racetronixs wiring harness and ground installed. The only thing i need to get is the fuel sending unit my gauge bounces alot and its annoying. Please help me answer the questions below...
                    20 gallon tank, am i correct??
                    What is the correct Delphi part number for my 93 ty. Autopartswarehouse.com says the following.
                    Part number: DPFL0157
                    Manufacturer number: FL0157
                    AdvanceAuto.com says part number is FE0114.
                    What is the correct one???? Advance auto with discount coupon is 101.99 shipped in 2-3 days. Cant go wrong with that.
                    Thanks
                    • #11
                      Quanta has them cheaper - http://www.quantaproducts.com/products.asp?dept=317
                      Also, did the gauge issues arise after installing a pump or messing with the current sending unit? Or did they arise out of the blue? Reason I ask is that I fixed a Ty once that had wild fuel gauge swings and we suspected a faulty sender. After dropping the tank we realized that the P.O. had installed the float rod incorrectly and it was the culprit. Fixed that and the gauge swings went away. Just a thought........
                      Michael Hood - Syclone #1596
                      I'm parting out one of the '92 Syclones!
                      Reserve your parts HERE!
                      "Many will seek God at the 11th hour only to die at 10:30."
                      "FWD is perfect as long as you're not accelerating, braking, or turning."
                      "Any car which holds together for a whole race is too heavy." - Colin Chapman
                      "Spiritually, everything should be turbocharged." - Turbo Yoda
                      • #12
                        I didnt install anything yet. I want to make sure i get all the parts first then im going to do the install all at once. Is quanta products any good?? Are the products they sell delphi or does it even matter??
                        Thanks
                        • #13
                          Thanks
                          Ya know.....I'm not sure. It personally wouldn't matter to me, but if you want Delphi, I'd give 'em a call and see what brand(s) they carry.
                          • #14
                            You know what Micheal i just want to make sure i dont need to do this again so if the price is close i would rather go with delphi. I really appreciate the help. If you can answer one more question....which unit am i going with on that list you sent me. When i look up gmc typhoon it doesnt have anything.
                            Thanks
