No Brakes after starting the engine...
  • No Brakes after starting the engine...
    I have been fighting this for quite a while now. After installing Wilwood calipers on the front of my 93 Ty, removed the ABS, installed the ABS delete kit, bleeding the brakes several times - I get a firm pedal while not running. As soon as I start the engine - pedal goes to the floor...
    Has anyone run into this or have clue what could be wrong??? I'm suspecting the power brakes but I don't think it would break just sitting in the garage.
    HELP
    thanks,
    Eddy
    sounds like a bad master
    Sy #0535
    TBSS LME LS2
    non outlaw hardtop 911S
    911s 3.2 turbo
    75 3.2ss cab
    LS1 SS cam and spray
    LT1 355ci procharger
    LT1 WS6 383ci
      Yeah, I thought about that but before I put the new brakes on, everything was working fine - brakes were working...
      Maybe I need to bench bleed it.
      thanks,
      Eddy
      • #4
        Anyone have any ideas??? I'm stuck...
        Eddy
        • #5
          If thereís no leaks, the abs removed and the system was bleed properly(dbl check), I would say itís the master also.........
          Sy 877 2271
          92 Ty 588 833
          85.5 SVO Mustang
          32" Beach Cruiser
