LSx SyTy Swap Information
This is a sticky topic.
  • #31
    Re: LSx SyTy Swap Information
    Originally posted by Norm View Post
    I have a video, just changed up the cam, and fired it up on weds I think.
    http://www.youtube.com/watch?v=OYsFjsEfsto
    Very nice!
    Which cam did you install? Did you change anything else in the valve train, intake, injectors, etc.?
    Thanks,
    Eddy
    • #32
      Did lots, trick flow heads, trick flow pushrods, roller rockers green top injectors. Also note I pulled the valve cover today and one of the rocker studs is broken and a push rod is bent. So much for car craft this weekend.
      1962 Chevrolet Biscayne( low and mean)
      2011 Toyota Tacoma 4x4( daily driver)
      2017 Street Glide Special yep two wheeled ride
      "If it has tit's or tires, you can be pretty sure your going to have problems with them...
      • #33
        Any tips on how to get the stock speedometer to work from the LS PCM?
        I found this link
        https://www.autometer.com/media/2650-1563.pdf
        10.4@127mph-stock ECM
        542 rwhp/ 608 Torque. PTE 67-V6.
        E85-TT-408"-AWD/4L80e under construction...
        • #34
          I found this link
          Yes, that is a interesting link. That should help you with most "issues".
          • #35
            Trans tunnel modification should also be added to this list, I was actually surprised at how much a couple inches of lifting the trans/transfer case dug into the tunnel.
            • #36
              only need to do it if you are going to a 80-e, 60e or 700 r4 doesn't require it. So not really mentioned.
              • #37
                I'm doing a 60e, if you want that pinion angle correct, it needs a bit of mod.
                • #38
                  are not 60e and 700r4 pretty much same dimensions? you shouldn't have to really change anything.
                  • #39
                    there's allot of good info listed but seems to be from years ago ... does anyone have any new info or products for a LSxx swap ... I'm fairly new to the SyTy scene and I'm considering a LS swap or rebuilding my 4.3
