SyTy/SGT - Forums Advertise on SyTy.net
Go Back   SyTy/SGT - Forums > General Discussion > New Members
Reply
Thread Tools Display Modes
Old 11-10-2014, 11:26 PM   #1
TittyTy
TittyTy's Avatar
Talking 92 Typhoon 0255
Hello everyone. Names Lance and I purchased my Typhoon outside Philly about a year and a half ago. She's a frost white /grey with 72,000 miles now. Wanted to to start a thread documenting the progress of the beast since my purchase. I bought her in august 2013 and brought her back to Virginia where she started her life (according to carfax) only to realize she was sitting on a blown turbo (massive shaft play). As I was replacing the turbo with a 6266e precision i stumbled upon a major leak in the ATR upper intercooler. Not knowing very much about syty's i ordered a run of the mill 650HP W/A intercooler from frozen boost and fabbed up my own intercooler/piping system. What followed was an unbelievable amount of brake downs lmao ( the true syty experience). This thing is a money pit and I'm so in love! After replacing almost every sensor, belt, and hose things have kind of gotten better lol. From what I have dug up this truck used to belong to a guy named Jay Levitt. Pretty sure I'm the 4th owner. The truck is far from stock and pretty much has the ENTIRE ATR catalog installed. Obviously its an older build that I've been trying to restore. I currently have a set of vortecs and a spare intake manifold to send off for vortec modification as well as a full code 59 /data logging, and Plx wb02 set up getting ready for installation. Just wanting to introduce myself and document the life of 92 Ty 0255 in this thread.
TittyTy is offline   Reply With Quote
Old 11-11-2014, 08:46 AM   #2
TyMom1754
TyMom1754's Avatar
Re: 92 Typhoon 0255
Quote:
Welcome we met you in Carlisle we had the white ty and syclone
You helped with our trailer. There is a ton of info on here enjoy your ride
TyMom1754 is offline   Reply With Quote
Old 11-11-2014, 10:21 AM   #3
Anarchy99
Re: 92 Typhoon 0255
Drive on over if you get bored... Usually bbqing and turning wrenches on something
Anarchy99 is offline   Reply With Quote
Old 11-11-2014, 12:13 PM   #4
Jamerjoe
Jamerjoe's Avatar
Location: Harpers Ferry, Wv - Sterling, Va (Washington D.C.)
Re: 92 Typhoon 0255
Where you at in Va? There's few of us around.
__________________
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
Jamerjoe is offline   Reply With Quote
Old 11-11-2014, 12:30 PM   #5
SEL777
One of 101
SEL777's Avatar
Send a message via Yahoo to SEL777
Re: 92 Typhoon 0255
Cool. Looking forward to seeing some pix too. More info on the frozen boost IC please.
Thanks, BTW...White and Gray is the best color combo.
__________________
92 TY # 398 - Retired DD - 162K and running good: 20G, JSM A-Arms, QA1 Coilovers, Beltech rear springs & SB, ZQ8, F-Body disks, Gilbert, built trans, 9/11 convertor, C4 ZR1 wheels, Hoods ABS delete, DutchTy IC & Johnson pump , RPM cat delete & Borla cat back exhaust, Code$59 tuned by Krupa running on E85.
97 Tahoe - Big Blue
SEL777 is offline   Reply With Quote
Old 11-11-2014, 04:44 PM   #6
TittyTy
TittyTy's Avatar
Re: 92 Typhoon 0255
here's a pic of the intercooler & piping
Old 11-11-2014, 04:53 PM   #7
NJ93TY
NJ93TY's Avatar
Send a message via AIM to NJ93TY Send a message via Yahoo to NJ93TY
Re: 92 Typhoon 0255
Lance I met you also at Carslile, try and make it to the NASTE meet this month! And good luck with your truck!
__________________
93 Typhoon, Blk/Blk
TY#1455, Stock motor, 20G turbo, 2800 Waller converter, Turbotweek chip, full 3" exhaust, AFPR, RPM front mount IC, 13" front disc brakes, 12" rear disc brakes, Walbro 255 FP, RPM 52mm TB, Astro van fan mod, fat tires.
I used to hate red lights, until I bought a Typhoon.
NJ93TY is offline   Reply With Quote
Old 11-11-2014, 04:57 PM   #8
TittyTy
TittyTy's Avatar
Re: 92 Typhoon 0255
[/IMG]
Old 11-11-2014, 05:03 PM   #9
TittyTy
TittyTy's Avatar
Re: 92 Typhoon 0255
Well obviously I haven't figured out how to post photos yet lol. Yeah man I'm going to be there with the Ty as long as it doesn't develop a sudden need for jack stands between now and the 23rd.
Old 11-11-2014, 08:49 PM   #10
Anarchy99
Re: 92 Typhoon 0255
I post everything via photbucket... Usually the easiest way
Old 12-15-2014, 02:31 PM   #11
TittyTy
TittyTy's Avatar
Re: 92 Typhoon 0255
Little update... So i started data logging and of course I'm getting a bunch of KR the second i past 15lbs of boost (running ultimate chip on T1-17 and yes I have a 3 bar map) other then that was getting some way ramdom light KR which I traced down to exhaust hitting in a few places. So i ripped out my s.s. atr pit bull exhaust to rehang it all properly and so I could remove the last piece of down pipe and drop it off to get a bung welded in. I got the plx dm6 all installed aswell, just waiting on the welding shop to finish w/my down pipe so I can get everything back on the truck and start trying to track down the cause of my KR in hi boost!
Old 02-14-2017, 09:04 AM   #12
TittyTy
TittyTy's Avatar
Re: 92 Typhoon 0255
Well this is long over due but better late then never. First off I tracked down where my false knock was coming from. The fuel lines were hitting the transmission so I slit a piece of rubber hose and wrapped it around them. No more KR for me!
Also since I suck outloud at updating this build thread I have accomplished quite a bit of improvements on the Ty over the last 2 years! I have pretty much gutted the engine bay and started over as it was a complete shit show when I bought it. The pile of unnecessary wires I removed was ridiculous!
Project engine bay consisted of A/c delete, repair and heat wrap my ATR headers and PTE down pipe, jet hot coated accessory brackets, valve covers, coil &throttle cable brackets, SM ABS delete, SM vacuum line kit, every hose under hood replaced, Ported wastegate on turbo for better boost control, added ATR Aux cooler and Ice box for intercooling system, pulled and painted inner fender wells, Taylor wires w/ new boot protectors, NGK UR6 plugs gapped at .032, new MSD cap & rotor, and wire tuck. All of this was completed shorty before Carlisle 2015. There is a shit ton more to report since then but I need to go to work now lol. I will be trying to get this thread up to date and maybe even figure out how to post pics within the next week or 2.
Old 02-14-2017, 06:34 PM   #13
Cronic fatigue
toe cutter
Cronic fatigue's Avatar
Re: 92 Typhoon 0255
Keep up the good work lance!
__________________
92 TY #0020
91 SY #0334
00 trans am: 9.83 @139 1.32 60ft.
Cronic fatigue is offline   Reply With Quote
Old 02-14-2017, 06:46 PM   #14
Anarchy99
Re: 92 Typhoon 0255
Where in Virginia?
__________________
64 Austin Healey Sprite - SBC/200-4r, 1456 lbs
69 Camaro - RS/SS Yenko Clone
70 Triumph GT6 - 9 inch rear, new engine trans to follow
71 Buick GSX Stage One Clone
93 GMC Typhoon - Built motor / FAST XFI
Old 02-14-2017, 11:41 PM   #15
TittyTy
TittyTy's Avatar
Re: 92 Typhoon 0255
I'm over in the Hampton area
Google Ads
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.9
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
SyTy.net 2000-2014
