SyTy/SGT - Forums Advertise on SyTy.net
Go Back   SyTy/SGT - Forums > SyTy Tech Areas > Chassis Electrical & Accessories
Reply
Thread Tools Display Modes
Old 02-13-2017, 08:04 PM   #1
red typhoon
big stuff3 problems need help
Hi, guy. I was wondering if anybody has had this problem. I have big stuff 3 stand alone and my truck,it was working fine instill I tuck all my wiring, and after that my car doesn't want to send any signal from the bs3 to the injectors. I have check signal from the dist to the bs3 and I get a pulse of negative, but nothing out from bs3. what cable color is the one out of the bs3 to the injector, so I can check it to see if I have positive instead of negative. help would be appreciated.
red typhoon is offline   Reply With Quote
Old 02-13-2017, 09:20 PM   #2
gringo76
gringo76's Avatar
Re: big stuff3 problems need help
there is a injector ground wire.did you forget to reinstall it ? other than that your normal power wires and pink switch ignition on wires, unless you got and separate injector driver box. if iam not mistaken, been a while but key on there should be power on both sides of injector and in running or crank then it pulses on the big stuff 3. like I said been a while since I had issue with injector issues on big stuff so memory might be off lol
gringo76 is offline   Reply With Quote
Old 02-16-2017, 02:23 PM   #3
red typhoon
I don't follow the system I have come the bs3 with the harness to install to the original plugs I don't see any ground can you elaborate more on were it goes.
Old 02-16-2017, 02:24 PM   #4
red typhoon
I don't have a separate injector drive
Old 02-16-2017, 07:59 PM   #5
0966Sy
Code what?
0966Sy's Avatar
Is this a piggy back harness to the factory harness or are you running a standalone harness?
If it's a piggy back harness, I would suspect you knocked something loose tucking your wiring.
__________________
91 SY #966
92 Teal TY #414 Nats 05 Pure Stock Champ
92 4dr T15 Jimmy 4x4
0966Sy is offline   Reply With Quote
Old 02-17-2017, 01:02 AM   #6
autoaddictions
Super Member
autoaddictions's Avatar
With your lap top hooked up to the truck can you see rpms when your cranking it over. Should see 300-400 rpm. If the Ecu doesn't see any rpm signal it won't fire the injectors. It will give you a idea where to start looking. I'm my case it is usualy a broken or coroded wire under the dizzy cap at the ignition module.
__________________
92 Typhoon #999 SEE 10.27 RUN
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
91 Syclone #788 SEE 10.22 RUN
91 Syclone #2891
autoaddictions is offline   Reply With Quote
Google Ads
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.9
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
SyTy.net 2000-2014
