User Tag List
Results 1 to 9 of 9
Thread: Idler Arm adjustment
Idler Arm adjustment Idler Arm adjustment
  1. #1
    dgoodhue's Avatar
    Join Date
    Feb 2001
    Location
    Framingham, MA
    Age
    44
    Posts
    12,440
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I am in the middle of rebuilding my steering parts. I noticed that my idler arm has some up and down adjustment. What is the proper adjustment procedure or do I just try to put it back to how it was with the orignal idler arm.
    Dave
    Sy #2661
  2. #2
    Super Member TurboTony's Avatar
    Join Date
    Feb 2001
    Location
    In My Snappy bus
    Posts
    1,708
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Re: Idler Arm adjustment
    You need to get the idler arm the same hieght as the pitman arm.
    Measure from the floor to the end of the arm and adjust from there. Of course that's counting on the floor bieng level and the frame bieng straight.
    Tony
    Sy# 2356
    10.71@126
    Stock ecm, stock manifolds, stock suspension
    '07 Sierra 6.0 Max crew cab<--not so new ride anymore
    Nolan tuned 370hp/360ftlbs
  3. #3
    Sell Out
    Join Date
    Oct 2001
    Location
    Chicago
    Posts
    6,049
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I seem to remember hearing - if it pulls left at the shift - it adjusts down and if it pulls right - it adjusts up? I think...
    Eh - tequila ownz me.
    RIP Myclone
    Smeagol's Therapist - I'm failing miserably.
  4. #4
    Member Blazin_Jason's Avatar
    Join Date
    Jan 2011
    Location
    BC, Canada
    Posts
    57
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Are there any other methods on adjusting the idler? There is no mention in my service manual of haynes book for s-series. The best I could come up with is measuring the center link gap between the frame when at full right. I figured the pitman arm side would be the base. Then I tried to get the other side as close to that same height.
  5. #5
    Join Date
    Jan 2009
    Location
    Northeast PA
    Age
    63
    Posts
    549
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Make sure the frame is level and put a level on the drag link, adjust the idler arm up and down until the drank link is level. If you don't have it set right, the vehicle will jump to one side or the other when you hit a hard bump
  6. #6
    Don W.'s Avatar
    Join Date
    Dec 2002
    Location
    Santa Rosa, Ca
    Age
    74
    Posts
    6,771
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm with Dave. Just be sure to not fool with it after alignment is set.
  7. #7
    Join Date
    May 2011
    Location
    Seattle
    Age
    43
    Posts
    78
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hey Fellas....I searched and found a link to the installation of the idler arm but it was dead. I know some of you may be rolling your eyes but I have never touched suspension parts on any rig I have ever owned. Now is the time to start so a little guidance and tips/tricks would be awesome.
    Thanks - P
  8. #8
    Don W.'s Avatar
    Join Date
    Dec 2002
    Location
    Santa Rosa, Ca
    Age
    74
    Posts
    6,771
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    And before you start, the issue is?
  9. #9
    Join Date
    May 2011
    Location
    Seattle
    Age
    43
    Posts
    78
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Don W. View Post
    The idler arm needs replacing......
    Everything has been checked and this is the culprit...Already have the part and i found instructions so nevermind.
Thread Information
Users Browsing this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
