User Tag List
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 46 to 60 of 65
Thread: Solution for steering slop?
Solution for steering slop? Solution for steering slop?
  1. #46
    Member whiteTy1214's Avatar
    Join Date
    Jan 2011
    Location
    Albany, Oregon
    Age
    37
    Posts
    104
    Post Thanks / Like
    My Feedback
    0
    (0% Positive Feedback)
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Re: Solution for steering slop?
    Great post! Went and checked my upper steering shaft. Found lots of play side/side & up/down.
    I will be getting this repaired very soon. Thanks for the part numbers!
    Hopefully this is a great improvement.
    ATR sy60 turbo, ATR headers, ATR 3" downpipe, 3" exhaust no cat, ATR wastegate, turbo xs mbc, ATR cold air kit, ATR i/c pump with aux heat exchanger, rpm afpr, 3000 stall, trans cooler, 63# seimens, code 59, electric fan kit, solid mounts, plx wideband, autometer gauges, electric fuel psi, boost,18" magnesium c5, belltech springs, egr delete, battery relocate to rear. greddy turbo timer :
  2. #47
    Combating adversyty. Quickstop [UK]'s Avatar
    Join Date
    Jan 2006
    Location
    London, UK
    Age
    38
    Posts
    6,655
    Post Thanks / Like
    My Feedback
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Where does this bearing go? What is involved in replacing it?
  3. #48
    Big in the rear DanenGraham's Avatar
    Join Date
    Aug 2002
    Location
    Lee's Summit MO
    Age
    32
    Posts
    1,708
    Post Thanks / Like
    My Feedback
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Remove the steering shaft, and its right there going into the firewall. Someone in this thread said it should take 2min to install once the steering shaft is removed.
    Syclone #1736
  4. #49
    Join Date
    Jan 2006
    Location
    London, UK
    Age
    38
    Posts
    6,655
    Post Thanks / Like
    My Feedback
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Cool - found it. Thanks!
  5. #50
    Super Member Throws's Avatar
    Join Date
    Jul 2011
    Location
    Portland, OR
    Posts
    1,641
    Post Thanks / Like
    My Feedback
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    How long does it take to get the steering shaft removed?
    -P
    Paul - Nuffin but a Huffy and a '65 Cobra replica with a 5.0 Coyote.
  6. #51
    Join Date
    Jan 2006
    Location
    London, UK
    Age
    38
    Posts
    6,655
    Post Thanks / Like
    My Feedback
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Throws View Post
    -P
    If you're good, 3 min. 2 min to undo the bolt and then 1 min to hammer/lever the shaft away.
    A screwdriver/rod in the holes for the bolt works wonders plus WD40 on the shaft.
  7. #52
    Join Date
    Aug 2002
    Location
    Lee's Summit MO
    Age
    32
    Posts
    1,708
    Post Thanks / Like
    My Feedback
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It took me over an hour to get the steering shaft out of mine. But the slip joint was ceased up and I had to drop the box. But It should be easier than that.
    Syclone #1736
  8. #53
    Join Date
    Sep 2011
    Location
    SoCal
    Posts
    1,560
    Post Thanks / Like
    My Feedback
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I was done in about 10 minutes. It takes longer to take the wheel off and then put it back on. I should have taken pics along the way. Just remember how the retaining ring goes in. The old "bearing" isn't even a bearing, it's just there for a reference than anything else.
    Sadly though, this did not help me. I still have shaft play. I have new everything now and I still have it. I got the ZQ8 steering box and I wonder if I need to adjust it some? It only has about 200 miles on it so far. The steering shaft didn't have much play before the new bearing. The shaft itself moves with the steering wheel but the pitman arm doesn't move, hence the steering slop. Any ideas?
  9. #54
    Join Date
    Aug 2002
    Location
    Lee's Summit MO
    Age
    32
    Posts
    1,708
    Post Thanks / Like
    My Feedback
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Don't adjust the box. People have had it lock up while driving after the adjusted them.
    Syclone #1736
  10. #55
    Join Date
    Sep 2011
    Location
    SoCal
    Posts
    1,560
    Post Thanks / Like
    My Feedback
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I don't know what else to do. I have the same amount of slop as I did with my old steering box.
  11. #56
    Join Date
    Sep 2011
    Location
    SoCal
    Posts
    1,560
    Post Thanks / Like
    My Feedback
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Im leaning towards my steering box being bad. Has anyone else got a bad box from AutoZone?
    If I have the engine off, and I turn the steering wheel back and forth, it sounds like there is air in the system, but I look at the fluid, and there isnt any in there. Ive been driving around with this steering box for awhile now and if there was any in there, it should ealily be gone by now.
    If I watch the steering shaft where it connects to the box and turn the steering wheel back and forth, I can see the shaft moving and all, but the wheels dont budge until I go past the slop.
    Anything I should try before I have to pull this thing out again?
  12. #57
    Plays with trucks. RealFastV6's Avatar
    Join Date
    May 2011
    Location
    CT
    Posts
    1,085
    Post Thanks / Like
    My Feedback
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Sorry to hear that wasn't the fix. I posted somewhere else (I thought it was here but not) the way to find out if you need to do this is just grab the top of your steering shaft and see if it moves (perpendicular to the shaft).
    Seems obvious I guess if you can see that the steering shaft moving into the box and the pitman arm isn't moving in kind that it's the box itself.
    Justin "RealFastV6"
    1991 GMC Syclone
    1993 GMC Typhoon
  13. #58
    Join Date
    Sep 2011
    Location
    SoCal
    Posts
    1,560
    Post Thanks / Like
    My Feedback
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I might try and tighten down on the allen screw a hair and see if that helps anything. I dont mind puting money into this truck if it fixes the problem, but Im not getting anywhere with this steering slop. Replacing everything so far and 2 alignment jobs so far and it barely did anything for me.
  14. #59
    Join Date
    Sep 2011
    Location
    SoCal
    Posts
    1,560
    Post Thanks / Like
    My Feedback
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    A stupid request/question, can someone take a picture of the steering box hydraulic lines or tell me which lines go where? Im pretty sure the fittings only go one way but I just want to double check.
  15. #60
    SyTy Registry SYO237's Avatar
    Join Date
    Jun 2000
    Location
    Central FL
    Posts
    13,254
    Post Thanks / Like
    My Feedback
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Figured Id add to this thread some reference pics of the new adapter and bushing. I didnt realize that the stock setup didnt actually have a bearing, but just an adapter. You can see the differences between the orig and new setup (size, rubber ring doesnt get reused). The new adapter has a larger inner diameter than the stocker, which is where the bearing comes into play to hold the shaft in place.
    You have to push the bearing into the new adapter and the bearing does face AWAY from the firewall when installed, which I figured out really quickly when the adapter wouldnt go into the shaft housing the other way.
    I havent had a chance to drive the truck yet, but the wheel does feel tighter than before. Very easy upgrade, took about 15 minutes total.
    SYO237@GMAIL.COM - PM BOX FULL!
    adam
    91 Sy #237 l 11 Chevy HHR LT l 12 2LT/45th Camaro l ex-Typhoons/SGT #1011, #366, #1181, #299
    l SyTy Shindig Co-Founder l SyTyNats Coordinator l ISTR - SyTy Registry l HowTune
Thread Information
Users Browsing this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Classifieds
test
test
US $1.00
