User Tag List
Page 4 of 4 FirstFirst ... 234
Results 46 to 48 of 48
Thread: Converting to an "On-The-Block" Oil Filter - How To
Converting to an "On-The-Block" Oil Filter - How To Converting to an "On-The-Block" Oil Filter - How To
  1. #46
    I hate rust atomicmecha's Avatar
    Join Date
    Sep 2013
    Location
    Germantown, MD
    Age
    31
    Posts
    409
    Post Thanks / Like
    My Feedback
    0
    (0% Positive Feedback)
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Re: Converting to an "On-The-Block" Oil Filter - How To
    Somewhat related to this... but does anyone have the part number for the gasket/o-ring for the block adapter on hand? Mine is leaking and I figured while I have the front diff and t-case removed giving me a lot of working room, I could replace the lines and seals. Get rid of the minor oil leak happening down there.
    Shade Tree Mechanic working the 9-5 to survive
    Current...
    92 Typhoon #1336 a work in progress...
    92 S10 Blazer VIN code "W"
    07 Subaru Impreza WRX STi
    07 Jeep Rubicon Unlimited
  2. #47
    Super Member sytyguy's Avatar
    Join Date
    Aug 2000
    Location
    Savannah, GA
    Age
    36
    Posts
    6,105
    Post Thanks / Like
    My Feedback
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by atomicmecha View Post
    Felpro ES70016
    http://www.hoodtuned.com/store/index...product_id=109
    Michael Hood - Syclone #1596
    I'm parting out one of the '92 Syclones!
    Reserve your parts HERE!
    "Many will seek God at the 11th hour only to die at 10:30."
    "FWD is perfect as long as you're not accelerating, braking, or turning."
    "Any car which holds together for a whole race is too heavy." - Colin Chapman
    "Spiritually, everything should be turbocharged." - Turbo Yoda
  3. #48
    Donating Member anryo's Avatar
    Join Date
    Sep 2014
    Location
    Estonia
    Posts
    101
    Post Thanks / Like
    My Feedback
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by hatrik8 View Post
    Is the adapter (GM part#14081300) the same part that is in the remote oil filter housing? Can you just re-use it if you pull it out of the housing?.
    I went doing the conversion last evening and can now confirm, that in the remote housing is not the same adapter. First, it seems shorter and second, it did not had allen hex socket inside, so it could not screwed out from the housing.
    I tried to screw it out with different pliers and even heated it but it did not came out.
    We live in a poor neighbourhood - we can only afford to drive old cars.
    '93 GMC Typhoon #1266
    '70 Plymouth Supercharged Hemi 'cuda
    '68 Ford Thunderbird 429cid BB
  4. #49
    Join Date
    Sep 2014
    Location
    Estonia
    Posts
    101
    Post Thanks / Like
    My Feedback
    0
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by canadian View Post
    1) Here's the adapter you need. Make sure you clean it well if you're using a used one. Short side goes into the block.
    BTW, our Finnish/Swedish users can use following part for replacement, if needed...
    (It's M18x1.5 on both ends, but it screws to engine block easily and although it can be used, I am using it only as temporary solution until correct GM part arrives and then it will be replaced with oil/filter change).
    http://www.ikh.fi/en/bulkhead-fitting-12mm-din10112l
Thread Information
Users Browsing this Thread
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
