DFIGen 6
TrendSetter
Organ donor in training
Is a DFI Gen 6 with adapter harness worth anything?
Long story short, it would be cheaper for me to cut the adapter harness up to install a megasquirt than to buy a 749 and associated bits to run code 59. unless that gen 6 and harness are worth anything. im guessing theyre worth exactly $0 though.
To clarify, the typhoon that I just bought came with a gen 6 installed and I have no interest in keeping it at all so i need a ecm solution.
fivetodrive
CRISPY
Re: DFIGen 6
Code 59 is pretty cheap if you know what you are doing. All you really need is an emulator stock computer and an aldl cable and a $25 moates g1 adapter and wideband sensor...
TrendSetter
Re: DFIGen 6
right now I only have the Gen 6 so i would need to find all that. I have a v2.2 megasquirt on the shelf from a past project so I would 'only' need the ms2 module and flyback board.
The biggest draw of the ms for me over the code59 stuff is datalogging.
fivetodrive
CRISPY
Re: DFIGen 6
The difficult part is that there are very few if any megasquirt guys on here. We datalog with datamaster and there quite a few people that can help analyse logs.
I have parts to get you back to stock if you wantedto go that route...
