Part # for tb gasket set?
skwayb
NWSTP
Re: Part # for tb gasket set?
http://www.sytyauthority.net/ has a listing of just about every part you would be looking for.
Gasket: Throttle Body-to-Intake
GM #10105351
Fel-Pro #60826
NAPA #G-31350
Victor # G31350
If you want the whole set.
Gasket set: Throttle Body GM #17113115
James Thomas
"NO CLASS"
GP Sorensen part number 96-3008: At Autozone for sure and only a few bucks! Napa, Carcrud er.... I mean CarQuest and others prolly have the same if not simular. I now keep several sets for those late night swaps and tweeks that somtimes result in a torn gasket. A light coat of thin grease on both sides helps them seal and will usually alow you to "peel" it off undamaged and reuse it at least once :tup:
More info here:http://www.syty.net/forums//showthread.php?t=47570
BTW the upper to lower plenum gaskt. is available by it's self and is also only a few buck, GM gasket prices will make you choke :tdown:
____________
James
