Time to shed some light on this. I get really annoyed whenever I see extraordinary claims posted with no specifics, so I did some research.
Reality #1.
David Buschur (head of the shop who built all 3 of these 550whp Evos): "A build like this if you have a bone stock EVO would be
around $25,000 from start to finish, all the best parts, labor and tuning."
Reality #2. They are revving to
8000-8500 RPM. Look at the dyno sheet and it doesn't even spool up until 5000 RPM (most SyTys' redline and shift around here!) That's a damn big difference.
Reality #3. The shop (Buschur Racing) is not interested in helping anyone make their own car fast - just interested in doing business with customers.
Case in point: "dave i know
you like to keep things to a minimum and secret. but any chance of you posting a timing map on one of these 500+30psi pump gas maps???"
His response: "Not only no but **** no on the timing maps." :roll: :tdown:
So what is the purpose of his posts? To drum up more business for his $25,000 builds? To brag and rub it in the nose of slower cars?
Anyway, 8500 RPM, the small displacement (the small bore especially), race ported 4 valve head, and cams are what are largely responsible for allowing such high boost on pump gas. The static compression ratio also plays a factor. World of difference here comparing these motors to a 4.3 V6.
