93 ty keeps dying out i dont know what it can be
sometimes the car will die out and wont start. But if i wait a couple minutes it starts. It doesnt idle low or high about 800 700. It used to do this like every time i drove it paticularly when it would heat up. I changed the ignition module and it stopped but its doin it again but not nearly as often what else can it be.
TyGuyJeff
Re: 93 ty keeps dying out i dont know what it can be
Check fuel pressure- pump might be starting to go south (depending on mileage/age of pump).
Just a thought :)
Just a thought :)
i just put a walbro in recently and it was fine for a while its only been like 3 months. I have fuel press and im not overboosting im at about 15 according to the auto meter gage i just bought. Im gunna check the iac but i still dont know what that is and ill check the egr too but some more help would be great.
motorhead
when it doesnt restart if you tip in the throttle a little will it start? if so it could be iac related.
do some quick checks:
check for codes
check fuel psi
when it doesnt start you have the opertunity to check for spark. buy a spark tester if you dont have one. the one that looks like a spark plug and had the alligator clip are best.
check for codes
check fuel psi
thanks will do thought it might iac related
