s10pro
I am redoing the engine due to broken crank. It already has t66 turbo, under drive crank pulley, kb headers, wastegate to work with headers, 3 inch downpipe and full 3 inch exhaust, kb air to air, kb intercooler piping, kb 4 inch intake, kb fpr, 40lb injectors, boshe 044 ext fuel pump, stock ported heads, eagle rods, trw pistons L2441, sfi flexplate, accel dfi gen 6 calmap, 3 bar map. I am not sure on cam specs, have to have it cam doctored. I'm also not sure on converter #20506r3. Prev owner had no clue what was done to truck, I am finding out the mods as I tear into the truck. What do you suggest?
Things I would like to do:
alky kit.
scat crank
have tuned with someone who knows dfi gen 6 (any suggestions?)
60lb injectors
converter (if mine is stock)
new rings (any suggestions?)
oil pump (any suggestions?)
double roller timing chain
what cam would be best for my combo
Please tell me what I should change or what is a better combo for my mods.
Thank you for your help. Kevin
alky kit.
scat crank
60lb injectors
