My plans call for a cylinder head upgrade in the near future. I believe I'll need more valve lift to make the most of the heads' increased airflow. However, I would like to keep the stock cam and just increase rocker ratio. The stock cam has .357 intake lift and .390 exhaust lift. With 1.6 rockers the lift would be .380 intake and .416 exhaust lift. With 1.65 rockers the lift would be .392 intake and .429 exhaust. With 1.7 rockers the valve lift would be .404 intake and .442 exhaust. Crane makes these rocker ratios and I would need guidplates and hardened pushrods, I have both items already from a leftover small-block Chevy project.
Crane tech also told me the effective duration would increase 2 degrees with the 1.6s and 4 degrees with the 1.7s. Crane recommended against the 1.7s because they are not emmissions-legal. However, he could not give me any other negatives on their use.
What does every here think? Anyone ever try this? What were your results? I'm sticking with the stock cam to minimize duration increases and the tuning problems that come with it.
