15x10 Weld ProStars With 28" Tall M/T Tires???
Sy-10
On Friday the 8th I purchased a Set of ProStars for My Sy-10
mounted on the rear 15x10s are L60 15 Mickey Thompsons.
....Ebay Item Number 150068978116 and 150068978116....
They are Old School Street Slicks, they measure out to be
28. I want to know if anyone has ever ran these on a 2wd SyTy??
I used them before on my 68 Olds' Cutlass 454W/500hp and a
Turbo 400 Trans, worked great because car was 4200lbs..
Also is there enough room in the wheel wells to fit a 14.25" wide
tire, without doing a Mini-Tub??
Thanx, :tup:
(Sy-10)Rob
Silly
Banned
Re: 15x10 Weld ProStars With 28" Tall M/T Tires???
I have the same combo with a 7.5bs. The fit is close but works. You will nto fit a bigger tire though.
Silly
Banned
canadian
sy in progress
Maybe it's just the angle of the first picture, but it looks like the tires are offset towards the front of the truck.
Sy-10
MarlboroTyphoon (15x10 Weld ProStars)
MarlboroTyphoon,
Can you post a full sided pic or 2
with the ProStars?? R U 2wd/Awd??
When I said Bigger I meant, Wider..
Thanx,
Sy-10 Rob
Silly
Banned
they are, about a 1/2" of inch or so not really sure why everything else lined up where it was supposed to be with the new 9" and caltrack and flexaforms and all that junk. Figured it was not a problem. Am I missing something you think?
Silly
Banned
Re: MarlboroTyphoon (15x10 Weld ProStars)
Sy-10 said:
MarlboroTyphoon,
Thanx,
Sy-10 Rob
Here is the link to all my wheel pics, not sure I have the one you are requesting
http://brokeassracing.com/Silly_Syclone/mike/Wheels_and_Tires/
I am RWD.
I know what you meant when you said wider and if you look at the 3rd pic you will see the tire is already close to the frame and that is a 10.5 tire so there is no way you are going to be able to add another 4 inches without minitubbing it at least.
