2jz Supra intank fuel pump
1madgumby
I belive this is the one IM going to try next.
Beavis
Still plays with trucks
Re: 2jz Supra intank fuel pump
have you ruled out the regulater completely? You might just want to bite the bullet and get the aeromotive and controller. then you shouldnt have to worry about it again.....:2cents:
1madgumby
Pump $300 controller $316.00 fuel lines $300. = $ 1,000 When trucks running in the 10,s with the stock lines & 255 pump. I want to find out the problum before I go out & spend that kind of money.
Beavis
How about the regulator, i got a feeling that might be it....
warmpancakes
300 for lines? what? you can make hardlines for under 100.00 also another thing to consider you can have all the pump you want but if the fuel lines can flow alont of fuel, its like 10 people trying to walk through one door at the same time . IIRC the supra has bigger fuel lines than our trucks
Or you can try a bunch of different pumps and only find out none of them work after the motor is hurt.
warmpancakes
I have a roll of 1/2 inch line here sump the tank install a external pump and build custom rails
VIPERRACING
Im using a denso intank feeding my other pumps. Works great. I just dont trust the walbro's and the supra TT pumps are one of the best. Make sure that its the TT supra pump and not the n/a.
