My A/C has been out for awhile. I have been hesitant to tackle it since I know nothing about A/C. My buddy works as a tech at a dealer and doesn't deal too much with A/C but knows enough to help, so we tried. He had access to a R12 evacuator and saved the remaining 1.5lbs in there, good thing I have an old can of R12 lying around too.
I'll be able to charge it back up. It's 2.5lbs right? how much oil goes in it?
Basically I am replacing the compressor, the drier, and the orifice tube due to compressor bearing failure. I purchased a new Delphi 3005 from Napa. The old orifice tube was completely saturated with metal shavings. We blew out the hoses with compressed air and hopefully got out the remaining shavings.
The new compressor is in (I'll interject that those bolts are a PIA to get off, they have a flat side to clear the pully, but you can't take them off from the back, so the bracket got chipped where the flat side used to rest
) The new drier and orifice tube are in, but we have a leak, it will only vacuum down to -15 instead of -30 after 15minutes.
The first suspect is the o-ring that goes on the orifice tube, the new tube did not come with one, so we had to re-use. Can someone please tell me a part number, where I can get it, anything?
The second suspect is the Compressor instructions did not have the compressor model number I have listed for what gaskets to use. The old compressor, the diameter of one of the holes was noticably smaller but the new one had two 5/8 inputs that were the same. We ended up not using the insert that may make the opening smaller as the gasket seemed to stick out to far. The two gaskets that came off the truck were both thin. We used one thin one included with the new compressor that fit perfect, and then a green one that was included on the other which almost fit perfect, it was a little thicker. Should I just get different gaskets here? Where can I get them? I'm assuming that the oem ones would be compatible with the compressor, am I correct.
The third possible spot is that we neglected to use the washer that goes between the input/output lines connected to the compressor? Mainly because my buddy didn't see where it came from and then we used it to go between a bolt and the right most bracket, the outer nut. Is this important to sealing? Where can I get one if so.
Any advice is grealty appreciated, I'm frustrated
We can do a dye test, but hope to avoid spending too much time, this thing already has 3 hours of my life, and his dealership is only open for limited hours to do personal R&R.
thanks in advance
thanks in advance
