I lost my air conditioning recently
I had replaced everything in the system last year, so I don't suspect anything mechanical.
When I switch to a/c inside the cab, I hear the vacuum system moving, but the compressor does not turn on. I tried checking voltage at the connector and had some odd readings of 300dc volts, so something must not be connected right.
Can someone point me in the right direction? I looked at the wire diagram and believe connector 138 is the one at the compressor, where is 137 relay control or 109 a/c wiring harness? maybe it came disconnected when I was reconnecting my vacuum line last week.
Thanks all
BTW: I picked up my grandfathers 97 Buick Skylark to be a better commuter. With only 32,000 what could go wrong? I'm going into week 2 and have already replaced the drivers window motor, battery, and alternator. Of course Oil, plugs, wires, air filter, fuel filter were just for fun. The tensioner pully on the transverse mounted motors is darn right impossible to get to with a ratchet, so I used a 6 foot concrete break bar and wedged it in there and used the sheet metal under the hood as a pivot =)
Bottom Line, it's not a syty thing, it's a GM thing.
Thanks all
