GEMELLI
The Best of Both Worlds
Since it's never going to end anyway, I figured I'll install LED tail/brake light bulbs. (Front stuff will come later.) I got them from superbrightleds.com, and they went in with just a little trimming of the sockets. Here's the weird thing though... the left side is flashing at a normal rate, but the right side is hyper flashing. I did replace my turn signal flasher with an EP35 unit before I started, but with or without the parking lights on, I get the same result. Right now, I have the stock bulb installed in the right side, and everything works as it should, but I certainly don't want to keep it that way. The hazards work just fine. Also, I'm trying to stay away from having to use resistors. Any ideas are much appreciated.
SOLVED IN POST 10
SOLVED IN POST 10
