Mobile22
SY#1819
I installed a Stage1 54mm turbo and am unsing a new factory actuator. I set the actuator with the proper preload. The problem is a major boost spike up to 25lbs and it falls back and stays at 10lbs. If you let off for a split sec and throttle up it will do it again. I adjusted the actuator out as far as possible and got it down to 20lbs but still the same drop in pressure.
Correct me if I'm wrong but is this is an indication the actuator is too small? I was hoping the factor boost module would bleed it to 15lbs and hold steady. Using the radar style chip and a 3bar.
Any suggestions?
Any suggestions?
