Camaro67racer
Re: Cleaning out my garage
payment sent for the black GMC letters
crazykaese said:What were those AN lines made up to fit exactly? Interested pending what they fit and what factory lines they replace.
12sec ss said:Click on the words for a pic...![]()
stock flywheel - $20
stock starter - SOLD
non-ac box with blower and resistor - SOLD
stock turbo -> intercooler hose - SOLD
stock oil feed line - SOLD
stock air filter elbow - $20
stock water pump pulley - $10
crank pulley, looks like underdrive - SOLD
front axle tube - $20
bracket with stock coil and egr solenoid - $20
stock power steering pump pulley - $10
driver's side accessory bracket - $25
stock intercooler - $50
stock upper intake with sensor and egr - SOLD
stock valve covers - $30
stock oil pan - SOLD
stock throttle body with no sensors - SOLD
'92 ty outside door handle things - SOLD
autometer silver boost/vac gauge and pod - SOLD
stock downpipe - $40
stock turbo, beat up impeller, side-to-side play but no front-to-back, made ~12lbs of boost before I took it off - SOLD
new monroe shocks - $40
new v8 swap corvette radiator - SOLD
new ultimate, gauge style, for stock injectors, new in the box with instructions - $420/obo
black GMC letters, all studs intact includes nuts - SOLD
1" wheels spacers - $20
arm rest plastic hinge - SOLD
headlight with bucket and trim - $15
stock corner lights - $10
orignal jack - SOLD
pair of H4 6000k HID bulbs only - $20
AN lines, 3-3, 3-4, and 4-4 - $10/ea
NEW Taylor battery relocation kit - $100
HKS additional injector controller, in the pic is all I have - $40
HKS Electronic valve controller, in the pic is all I have - $40
'92 TY rearview mirror with maplights and the metal windshield mount - $20
stock distributor - $35
'92 TY glovebox door with badge and lock - $40
radio suround with cig lighter and rear window relese - $20
HKS exhaust temp gauge with pod, no sending unit - $25
VDO fuel pressure gauge with pod, no sending unit - $25
'92 TY cluster surround with holes on both sides from gauge pods - $25
Spearco vac / boost gauge with pod - $25
charge air temp gauge with pod, no sending unit - $25
power steering cooler, tube with fins with barb fittings on both sides, little dirty - $25
3/4" hoses to go from CCHE to the intercooler, through the passenger fender - $20
lower CCHE with new Johnson's pump and brackets - $150
Upper intercooler - $50
stock throttlebody with sensors and airfoil - $50
supersports10 said:the private messege seems to be down so i will respond here....
you have cash!!
money sent for shocks.
