DEAD ALDL port WTF
SpoolingTurbo6
I went to plug in a(Crap-On) scan tool to the aldl I cant retrive anything !
I need to know if there is power to it (key on)?
how can you test it
AND TO TOP IT ALL OFF my map sensor went out
what the *&@#!% is going on
TY#1924
ALDL
ALDL
Quick way to check ALDL port:
Jumper on the trucks ALDL connector the upper right 2 pins, then turn key ON (up instrument lights should light) to AUX, the check engine light should start pulsing 1 then 2 (12) for a total of 3 times, after this trouble codes should flash. I can not remember which syty site has the trouble codes but is findable from this site, should be in the scanner manual.
I've never used a scanner to pull codes, should also have to turn key ON to pull TC's.
Hope to have helped.
Jim
SpoolingTurbo6
Tryed that no luck
Tryed that no luck
Yeah it's 2,800 pile of nevermind. the boss let me use
I cant seem to get it to diag. anything It tells me no aldl info strange!
I know it works we used it a 3000gt today and we sall all kinds of info
it does as much as turbo link? well almost
Thanks
Tyson
SpoolingTurbo6
Y
Y
Yes Iknow all this but it would be helpfull if I was new
I am trying to find out why it is dead DEAD nothing no power!
As far as I can tell it was no cuts or anything like that
i had the same deal and it was kicking my ass.
turns out - ecm worked perfectly, truck ran fine, blah blah blah.
ecm was indeed bad - least that part of it that barfs up info.
swapped to a spare, voila, data spewing everywhere.
try another ecm b4 you pull your hair out.
SpoolingTurbo6
Thanks
Thanks
The truck does indeed run OK!
I have some 3bar images I'm trying to find Why it starts hard in
the mornings. starts and dies about 3 times them idle flux.for a while
I thought if I hooked up a diagnostic tool I could see in real time whats going on does that help?
Iv'e been so pissed at it ,I'd I don't always know how to explain
Tyson
