Done light driving me nuts
VinPecora
The dome light in my syclone works once in a while doesn't work once in a while. It's driving me nuts cause I can't figure out what it is and it's definitely not a fuse I checked the mall many times. Can someone help me out here please
Slyclone
Well-known member
Re: Done light driving me nuts
I would check up by the alternator.
There is a bunch up there. 1st manifold stud I believe. Driver side.
Check it out.
Also check the bulb where it goes in. Sometimes that can be funny. Possibly a intermittent connection.
VinPecora
Yeah I check the connection by the light, Is there a specific ground for the dome light? Everything else including the horn works perfect???
Slyclone
Well-known member
I'd check the grounds up by the front.
I think the horn would pick up its ground via the mount to the rad support through faster.
I recently messed with the brown wires? With eyelet connectors up by the front of intake manifold.
Also.. Those fuse type bulbs can blow. Sometimes the element can bounce around in glass and make contact. Its a little coil thinner than dental floss.. I'm not saying that's the problem but it could also but something to check. I replaced my domes with LED lighting.
gstacky
Door switches? They work on ground, and when the door is open they ground completing the circuit. They just unscrew out, and have 2 wires on them, once comes from the light circuit, the other goes to ground up under the dash. Maybe one switch is acting up and not grounding.
Also, is it just the overhead light acting up, or do the ones under the dash not come on either? The 2 have different power sources, but use the same ground to turn them on.
These also work through the headlight switch, so maybe that may be giving you problems too.
DaveP
The dome and underdash ctsy lights are grounded at the door switches, and the panel dimmer switch. The next time the dome light "doesn't work", open the other door, or turn them on with the dash switch. Do they now come on? If = yes, the first door switch is dirty and intermittent.
Remove it, push the pin in to clean the contacts, squirt some contact cleaner on it, and screw it back into the jamb. Don't attempt to remove the wires, the little spades are fussy and you'll break the switch.
The suggestion to observe if the underdash courtesy lights work when the dome light doesn't is a good one. If = Yes, there is a connector to the rear dome light under the carpet, about 10" below the fuse box. One orange, one white wire. Check for it being loose.
Don W.
Lastly change the bulb. The element within the bulb may be broken but still making occasional contact.
SY2932
Administrator
I did have an intermittent issue with the dome light in my '88 which ended up being the orange/white wire DaveP mentioned. The previous owner must have had the seat out for some reason and the wire got misrouted in a way which kinked the wire. This cracked the insulation and the wire corroded into blue/green dust. These wires are not individual wires BTW, they look like zip cord or speaker wire and are joined together in the middle.
kmack
:tup:Lube your door switches
betcha one is sticky and not grounding
