Down pipe with external wastegate
gobabygo
I am looking for a down pipe setup for external wastegate. I have a 70 mm Garrett
Re: Down pipe with external wastegate
If stock turbo you will be looking for a lifetime as it is not possible.
So you might specify type of turbo
Syclone22
Do you think a ATR downpipe with flange will work
these were used on the GN turbo,s ..
gobabygo
I don't know really. I would have to see it to tell. I like the external waste gate setup. I have better luck tuning my turbo boost.
THEMADTYPH00N
The wastegate hole is in a slightly different location and one bolt hole is different from the Syty Housing. It could me made to work with some machining.
I have 38mm wastegate turbonetic dor sale Used less then 50 mile is was on a rpm downpipe
Syclone22
You are correct the ATR turbine flange has a different bolt pattern
compared to the RPM PTE flange but it can be machined to work
i was running this with the GN turbo,s and ATR headers i did dump
the external ATR wastegate in atmosphere and block off the return tube .
