dustinwinkle
1993 #0036 White/White
I just got the new engine put back in my truck and am having a problem. When I turn off the key, the engine will not stop running. It stays running just as if the key has not been turned off. With the key off and truck running, the dash gauges remain as if the key was still on. I killed the truck by pulling the coil wire.
I have tried several times with the same results. Also, the key and dash seem to function correctly before I start the truck.
My first thought is the ignition switch. Has anyone else had this problem?
Thank you,
Dustin Winkle
93 Ty #0036
Thank you,
Dustin Winkle
93 Ty #0036
