jdeangelis
What are the two, appear to be threaded, holes for at the bottom of the Flywheel cover? Is something supposed to go in them?
skata said:those two holes are universal. on some other vehicles they are for attaching a brace to the engine on each side.
i think on syty's one of the holes is used to attach a clamp/bracket to hold the trans lines in place.
jdeangelis said:I mean the 2 threaded holes on the bottom of the inspection plate. Doesn't that plate/cover protect the flywheel? Also, I did drop it a little to remove the starter. It looks like to take it off, you need to remove the prop shaft.
