Front end limiters
blk00z28
Forced to by choice
Re: Front end limiters
Hey Mav, got another question.
How come on the lower stop brace. It looks different then mine.... Mine is more of just at an angle. To where your's looks like its flat, and has a raised part where the bolt touch's it?? The reason why I ask this is because when I mocked it all up. And just tightened the bolts without welding the upper/lower one. If I tighted the bolt to far it slipped off the stop. :squint:
I didnt have the means to weld the nut to the bottom of the upper A-arm. So I welded one to the upper side of it, and will put the jam nut on the bottom. (Everythings in right now. Finished it up tonight. I'll take pic's when I can borrow a friends camera
denny
Which side the limiter goes, dirver or passanger side? or both ?
Does it matter which side?
Thanks
Six-is-Enough
Use to do a little Boost
Thanks
Use them in both and if you want to be real trick set the drivers side a little tighter(lower) than the passenger side.;)
