FS: block, crank and caps, trw pistons, vortec head
clone 94
14099073 block with lifter retainers
Crank for this block
Nodular caps
$100
Rpm a/c delete - $100
bowtie heads with Manley valves and alum roller rockers and arp hardware. Will work with stock syty intake or the stealth ram listed below. 14011053 casting
$700
Holley stealth ram, about 75% complete with conversion. Has rails, 50# injectors and lt1 throttle body. Need to have unused ports closed up and mating surfaces decked.
$350 shipped
randy merritt
Re: FS: block, crank and caps, trw pistons, vortec head
Do you have a part # on the pistons? I am doing a stock rebuild and may be interested.
clone 94
Added some items. If someone wants the heads for free lmk. They are going in the trash this weekend. Same with the balance shaft block
atkonkler
Is this your bush?
Pics and dibs pending pics of tubular heads and Syty Block
Syty84
I need the crank for the non balance shaft block.
