Does anyone know what controls the factory gauges i tried to start my truck for the first time since my build and nothing is working it started but we shut it down since we couldnt check oil pressure dont know what it could be no blown fuses
thanks blkty
i know the temp guage has it's own sensor. the oil pressure guage is off the sensor behind the block. if none of them work on the cluster i would think you're missing a ground wire or something.
I think either the ground at the driver's side front intake, or driver's side rear cylinder head is the ground for the gauges....IIRC.... maybe check those out.
does the computer control the gauges could the computer be screwed up took out gauges dont see anything out off the ordinary im lost dont know what else to look at
