Re: GP: traction bars
I been keeping very close contact with Brandon today and we been talking a lot, he has been watching this thread even though he can not reply.. This is was he sent me to post for you guys
"Great product. That's a Caltrac bar, not a traction bar though.
That bent bottom plate is a problem. The fatigued metal will continue to deform under the pressure of the u-bolt. As it continues to bend, the u-bolts will get loose. Double nutting is an easy fix...assuming the nuts are the right length to perfectly fill the space. However, the right way to engineer this would be to discard the stock bottom plate and design a new plate that replaces it and includes the caltrac tabs."
Caltracs is a brand name. And I can't go around saying I build Caltracs. I'm sure they would frown upon that. lol.
Anyways, the bottom plate IS and issue on Jesse's truck. It is only this way because he agreed to be my test dummy. He got the prototype, I guess you could call it. For anyone who orders these, they will have longer tabs that will rest on the factory leaf plate, and may still give a slight bend, but nothing that will cause the metal to fatigue and loosen up on the u-bolts. I do however, recommend that each nut and bolt associated with this kit be re checked after 500 or so miles. Just for your piece of mind.
I started off using 1/4" metal for that plate, but it was overkill for sure. 3/16 is perfect, I think.
I appreciate your input!
Branden
