Hi!
I wanna put a bigger turbocharger on.
So im confused about those 1 million diffrent chips and everything. I think thats much to comlicated and not good enought....
Im thinking about a other idea to controll ignition and fuel.....
Im planing to use a HKS AIC contoller. With this contoller i can put up to 8 (i would use 6) more injectors to put fuel in to the engine when its more than 14psi what the stock ecu can controll. There is a HKS 2bar Mapsensor in the kit and a rpm pickup as well. I can use the rpm signal and the boost signal as well, so then i can make a setup.... For tuning i would use a wideband.
To controll ignition i will use a boost timing master from msd or summit. There i can reduce ignition timing on higher boost, in this kit is also a 2bar mapsenors with.
With this idea, i have to weld a other manifold where i can but my 6 plus injectors in, and put a fuelrail on it. I would use a 255 walbro fuelpump and would make a new fuelline where i wold use a y-pice to feed both injector-systems, then in a fuelpressureregulator and back to the fueltank...
What do you guys think about this idea??
Do sombody else use a setup like this???
Best regrads
Best regrads
