how to upgrade stock steering box to a quicker ratio?
QUICK STORM
B.A.M.F. BMW Tech
Re: how to upgrade stock steering box to a quicker ratio?
never fixed it. i can assure you the truck was never wrecked. rpm and js frame pads are the same. zq8 and stock steering box have the same casting numbers just different guts.
to rectify the situation i picked up a set of ported and extrude honed stock manifolds and man they look amazing!
Syclone Rob
Its all ABOOT the SYTY eh
post from the past...... Did you resolve the steering shaft issue??
93 typhoon
QUICK STORM said:
Mike sales a steering shaft that i think you have to use when you buy the headers. But i see you went back to the stock manifold.
good luck on your truck sale :tup:
Black Knight
I Glow Therefore I am
Mike and Branden were trying to make this work for a while, I'm pretty sure that if he needed his special steering shaft it would have came up.
QUICK STORM
B.A.M.F. BMW Tech
it did and it still didn't work. mike is a great guy and refunded me my money, definately a great vendor.
Philntex
Header Clearance
Header Clearance
There's not much else you can do, unless you look at the firewall where the steering colum is mounted. You can remove the 4 bolts, enlarge the hole to the drivers side about 3/8" and re-drill and re-bolt the bracket to the firewall. This will give you 3/4" more room.
I did this on my 86 Blazer to get more clearance for the exhaust manifold when I put in a 5.7 TPI.
It moved the steering wheel inside the truck just a little, so it wasn't completely centered.
Here's a picture from JTR's book on S10 V-8 Conversions. Author of book is M.Knell.
QUICK STORM
B.A.M.F. BMW Tech
the problem wasn't on the firewall but rather on the box itself.
i also have the headers and had the same problem. mike is sending me a bare set of rpm frame pads to raise the engine .250" and all will be good. i could probably get away with it as is but i'd rather have a lil more clearance. i also have nothing but great things to say about mike lee. he's a great vendor here.
supersports10
remove lower 10 mm bolts for the steering column move to desired location, drill new holes, ....
done.
SS
QUICK STORM
B.A.M.F. BMW Tech
done.
SS
i said there wasn't an issue with the upper column.
