Ic Pump
tfink660
Ok so i think im going to order this pump model to upgrade my Stock pump to get a little better flow going anyhow. What have you guys that upgraded your pumps use to mount the new pump and where did you locate it cause this pump is bigger then OEM
SHURFLO RV AUTOMATIC DEMAND PUMP 2088-403-444
Espritmike
Re: Ic Pump
On the subject of intercooler pumps. I've noticed a few people mention kinked hoses causing a problem. You cannot bend a 3/4" hose without it kinking. I removed my fan shroud while doing my motor and the hose coming off the pump-to-motor was kinked. I replaced mine with this Gates hose.pn# 28479 it's got a 90 deg end and is about 36" long. Cost about $15.
Espritmike
Re: Ic Pump
Do you have your metal IC lines re-routed/replaced? If yes, did you buy 4 or just 1?
I flipped back and forth on this one. I ended up keeping the stock steel tubes even though it may hinder some performance I wanted a more "stock" appearance. Looking under the hood the only "non-stock" item is an adjustable fuel pressure regulator. If you run that gates hose on the pump its just long enough to reach the pipe behind the alternator.
TNPhoon
1of28
Re: Ic Pump
Cool, thanks. I am keeping as close to stock as possible as well, but going to go ahead and do the reroute.
TYRODD
My ass. Look at it.
Re: Ic Pump
http://www.napaonline.com/Search/Detail.aspx?R=NBH9820_0158804067
Napa PN: NBH 9820
I use these hoses on the upper IC connections.
The difference with this hose, verses the gates hose above, is that it is 40". If you are running your heater hose through the PS fender, the ends of these hoses will be accessible through the opening behind the overflow tank. This makes for a cleaner install, as the hose connections will be hidden...
:2cents:
TNPhoon
1of28
Re: Ic Pump
How many? 2 or 4? Can't remember the angles from underneath when the lower is hooked up plus will be coming from the opposite direction as is stock.
TYRODD
My ass. Look at it.
Re: Ic Pump
If you go my route, you would need at least 2 of the 40" hoses, from the top of the IC, and at least one other "long" 90 coming off of the CCHE, and one short 90* to connect the pump to the CCHE. you will still need a section of 3/4 heater hose.
In total, to replace the stock metal lines you will need at least 4 90*s, 2 for the upper IC, and 2 for the lower CCHE.
Ruddell
Re: Ic Pump
I jumped on the big bandwagon and removed the metal IC lines and did the full heater hose reroute. I can proudly say that I will be putting the metal tubes back in ASAP. I hate the reroute and personally think it is completley pointless.
Re: Ic Pump
I don't know how much the rubber lines really help the IC temps. The big advantage over the metal lines is that you don't have to drain the IC everytime you remove it. It is also makes it easier to get the air bubble of the system. I will replace the metal lines everytime unless I was doing a 100% stock SyTy. My Sy has perfect metals lines, my Ty that I owned had rusty lines that someone bent.
TNPhoon
1of28
Re: Ic Pump
Just out of curiosity, why did you hate them? The look? Functionality?
Re: Ic Pump
Most of us use the Johnson pumps (previously the popular upgrade was Jabsco pumps) that bolt into the stock location. The high flow capacity pumps benefits are questionable, Lower CCHE can only exchange so much heat, moving liquid faster doesn't neccessary help it. I put my Jasbsco pump in a bucket and I don't think it took 15 secs to pump a gallon, I am sure the tubing slow that down. The stock pump is probably adequate, but at this point the originals are all broken.
leusgs
Re: Ic Pump
I removed my metal lines mainly due to the clutter they create. I usually prefer a factory look, but the factory design is not pretty or functional - the metal lines clutter up the area, partly reduce access to the back of engine area and distributor, make checking vaccuum hoses a little harder, and so on.
I was able to use plain old straight 3/4 hoses. The bend at the intercooler is gradual enough that I can loop around into the fender without the 90 deg hoses.
Matt
Re: Ic Pump
pointless i guess if you like detonation and want to kill your engine :tup:
jollygreen1964
Re: Ic Pump
anyone interested in the bosch pump a ford dealer in minneapolis sells ford racing parts and the pump is used on certain mustangs and on the lightning, they sell the pump today for $88 plus $10 shipping , they also can supply the pigtail for wiring. Call 1-800-328-9552 ask for Steve or Mike R, it is Tousley Ford
