Re: Insanely Rich Please Help!!!
The one Mean Face is talking about is right on the T-stat.. tan and black ground.. Could let the ECM think the Water temp is open (or very cold) Which would make it run very fat.
Un-plug the wideband when it start to run rich.
Strange that it starts up at 14.7 runs for that short duration of time.. I don't think that's long enough to go into closed loop.... IE.. it looking at the wideband.
Make sure the wideband numbers on your AEM gauge are matching the numbers on the laptop/Datamaster. If not.. adjust the tables to make them read correctly.
What size injectors are you using?
I've got a decent 65lb/hr startup for AEM wideband program.
Send me mail if you want to give it a try.
~Scott
4 bolt, 030 over, TRW L2441, Eagle rods, Comp 415, Cometic, Vortec heads, Comp Valvetrain, Billet rails w/ RC750, Custon A2A, PTE 67mm, Synapse WG BOV, ATR headers and dp, Code 59 (Mario's bin), 8an line, Relocated fuel cell & battery, Aeromotive A1000 & Reg, AEM wideband, Turbo XS Knocklite
I checked that ground yesterday. Front right stud on the intake manifold, right? Right below the Alt. The AFR is about .3-.5 less than the Tunerpro.
