installing heads.
SpoolingTurbo6
Re: installing heads.
use some lucas under the bolt where it contacts the head.
GOOP up some white thread sealer on the threads.(Pipe Dope)
gjp
another post whore
lucus...isnt that 2 stroke oil??
and pipe dope?? I actualy have that on my shelf. Sounds like anything will work as long as you dont put them on dry?
I have teflon locktight??? Why not that
gjp
another post whore
did one side today. You can see pics in "my small project". I went with Mike lee's idea. He said to use arp lube on the bolts and washers. And use black rtv on the threads to lube and seal them. He said to torque down to 75lbs. Used my chiltons for bolt pattern and did a 25lb, 50lb, 75 lb sequence. My next problem is the heads I bought have different rocker posts on them. So I have to get new ones .
