420
Broke Ass Racing
Re: Interest Thread: Wavetrac Limited Slip Front Differential
It's this squirming that I am most concerned about, because it can be violent enough to put a truck into a wall, or the other lane. There are other tools to address overpowering all 4 wheels. I still think putting together a group buy is a little premature, especially at $1200 a pop. I would want to see the difference that the Wavetrac makes in a big HP truck before I shell out that kind of cash. The technical explaination sounds like it will be safer than trying to run a locker up front for sure, but I guess I want to see how much ET a $1200 piece is worth over the stock open diff before I jump in line (especially in this weak economy. I be po' yo!)
Now a limited slip wouldn't solve all of those problems but it certainly would help. The problem happening in the video above is both front wheels are spinning but one side of the truck is lifting more then the other. This causes the wheel with slightly more weight to pitch the truck sideways. Now that because the locker is the unit being used and the wheels are Locked and can't spin freely of one another they have a 1:1 bias ratio. The wavetrac however can alternate this bias ratio to accommodate. As I mentioned before a limited slip would definitely not solve the main problem here and that's simply more power then all 4 wheels can put down at one time. It would however help with the squirming off the line.
