JASPER ENGINE & TRANS. MESSES UP!!!!!
Status
Not open for further replies.
SpoolingTurbo6
Ok it was not a good decision on my part but it seems like a good one at the time.
Sy transmit ion went out on the coldest week of the year (12-? -02) in Indiana
I had no funds what so ever and didn’t know much about sy-ty.net at the time or people in my area that could help find a sy-ty transmition.
So Jasper gave me a good deal WITH OUT Vaseline.
What did I care it was cheap! And they offered a direct replacement.
Then while installing it Mr. Trans messes up one trany line so the try to find one it’s
Out of stock at GM so they rubber it up get it done yada yada yada caching .
As I’m diving away I notice that it won’t pull down into 1st.gear (linkage)
Well, they fix it And then it shifts like a mule from P to D WHAT NOW?
Don’t know to this day what that was, oh well .
I begin to notice the stall range is not the same so after being fed up with it for so long I e-mailed the a letter calling there bluff on a quote I fond online
“JASPER remanufactured products are built to industry specifications that are equal to or more exact than those used by the original equipment manufacturer”
I wrote an e-mail telling them they didn’t build the one I have correctly.
They finally get a hold of me. Apologizing out there miserable asses,But it did not matter I just want it fixed.They supposedly put Lt1 vaulve-bodie,
Corvette clutches corvette pump and a supper servo in it
Honestly it feel like only a shift kit. That’s why I requested an itemized build list for this trans. If it ever goes out I’m pulling it apart to see if
They did put this crap in it or just drilled it here filled it there.
So they offered to pay an installer or me
45.00 hr x7.4hrs.To put in the correct one.
Well I have the new stall converter(not the first one Iwas supposed to receive)
Yeah Fed Ex lost the first one!!Hahahahah!
Jasper overnighted one to me. So there is still another one floating out there
Somewhere last known at Memphis TN. Monday I’m taking it to a local shop to have it installed since I have exhausted all vacation waiting for the fist stall converter. Just letting you all know you aren’t the only ones …….well you know ! What do you all think,other than get the Vaseline first next time?
Later
Tyson
:grab: :grab:
Tydriver
TurboLS6 Powa'
So any reason you felt the need to post it in 3 separate areas on the BBS?
Please be advised posting in ONE AREA only is acceptable.
Posting the same topic in multiple areas of the BBS is not only a waste of Bandwidth, its a good way to piss off not only fellow members, but the moderators.
Please refrain from posting in multiple areas again.
One topic in lounge was/is removed. I will lock the one in drivetrain.
ONE POST PER TOPIC IN ONE AREA ONLY !
Status
