JSM wrench fest Nov.27&28& Dec 4-11th *NOW WITH PICS*
Six-is-Enough
Use to do a little Boost
Re: JSM wrench fest Nov.27&28 *NOW WITH PICS*
So your swapping out a small block for a big block I see. You might have to upgrade those "training turbo's" with that swap. Look out for when Dennis is over with his truck on the lift you will all hit your heads for sure.
Jeff got a BIG CAM to install an needs more flow from his big port heads.:lol:
As far as Dennis goes Jack stands are plenty tall enough for him to stand under.:tup:
Big Mike
LoL BIG CAM I hear Ya.
UR50SLO
V6+2=LSXCamaro
Re: JSM wrench fest Nov.27&28& Dec 4-11th *NOW WITH PICS*
Yea.. I caught that BBC heads pictures... Nice try :)
Glad you found the problem with the trans.
Sounds like fun guys!
~Scott
Six-is-Enough
~Scott
Can't slip nothing past you:rant:
Any updates/pictures on Jeff's frankenstein t-type?
Six-is-Enough
wow you got some serious real estate on that forehead...
Dobrick's camera on his phone made it look a fivehead! Its not that bad. I hope....:oops:
UR50SLO
V6+2=LSXCamaro
Proof Jeff has Crack. :)
Lifter valley is all cracked from freezing at some point. I pulled the intake to put on the 86/7 setup on it and found coolant seeping from the cracks. It actually bowed the block outward!
So.. we are on the hunt to find a donor block to repair....
Or he can buy the Camaro motor and I'll go Stage2 :)
Six-is-Enough
Confirmed attendees for Saturdays Dec 5 wrenchfest:
Dennis-crazykaese
Jeff Scott-twinturbov8typaintedblackwithbustedtransmission
Dobreak-2kwik4u
HARDman-heavybreather
Todd-tydriver
Jeremy Duncan- Six-is-Enough
And the newest JSM member
Dave-dalwine250
Should be fun! Everyone is welcomed to show up!:tup:
Daron
Who's engine is in the pic? I thought Jeff had a V8. That's a V6. Judging by the wire harness, and fuel lines, that may not even be a SyTy. There's so many engines apart on here now, I can't keep track.
T-type motor maybe?
UR50SLO
V6+2=LSXCamaro
Correct.. it's a 86/7 GN block... On Crack.
So.. snooping for a donor block to throw all the guts into and start fresh. I think the heads are ok... but I'm going to have them checked anyhow.
~Scott
Six-is-Enough
Scott, Jeff, & Dennis are doing a crossed legged trade.
Scott got a project Sy from Dennis.
Scott is fixing a ragged out t-type for Jeff. That is the motor in the t-type in the picture.
Dennis gets to use Jeff's garage to mod his Ty.;)
We will try and label things better in posts for here on. Didn't think anybody not in the know was following.:lol:
dalwine250
i stuck dennis with a screwdriver saturday and made him bleed.
